Question about Whirlpool Water Heaters
Whirlpool will not stay lit, having to relit about every month
Before calling service technician, open following links for help diagnosing common causes
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Corrosive-atmospheres.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 02, 2011
My water heater will not stay lit.
Make sure that you used the correct thermocouple. If so then you probably have a bad gas control valve. Also make sure that there is a drip leg in the gas line.
Good luck,
Marty
Dec 06, 2012 | Whirlpool Water Heaters
My water heater pilot light will not stay lit
1) Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake located on bottom of heater of American, State, Craftmaster, Reliance, Whirlpool, Kenmore
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
3) Gas control valve thermostat might be bad.
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
Richmond power vent will not stay lit, the bunrer will lit than after about 5-10 min. it goes and tries to relite and than goes into lock down. after it about 5 min. you can reset it and it will do the...
Richmond-Ruud-Rheem
It sounds like you've read the manual.
And cleaned the burner parts according to manual.
You replaced thermal reset, but system is still tripping, so either the gas valve and tubing are bad, the thermocouple is bad, or there is a problem with gas pressure, or gas line.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Apr 08, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water heater pilot keeps going out. Relight and may stay lit for a day and then goes out again. Now won't even light at all. Has an igniter button. Also says to clean intake screen every 6 months. Where is...
the intake screen or as is called flame trap is located on the very bottom of the heater underneath. this is very important that you keep this clean or it will keep going out. this is the only way this heater has to get air to the burning chamber.
Nov 23, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a bradford white 40 gal gaswater heater.the pilot will not stay lit.after i light it it fires right up and runs untill it reaches the set temp.then needs to be relit
just the week i repaired a b/w w/ same problem need to replace the temperature control (part where all the lil tubes connect and button where pilot is...shud be on 800 number on w/h or go online www.bradfordwhite.com and enter serial no. might still be under warrnty if not probably cheapr to get new water heater
Nov 18, 2010 | Water Heaters
Whirlpool water heater pilot light does not stay lite
I have a Lowe's Whirlpool water heater. I've experienced the same problems as I've seen described here. My pilot light started going out several times a day. It was not such a big deal, the tank is well insulated so the water would stay warm - I'd just re-light the pilot before going to bed and before going to work. That worked well for about three days, but the problem got progressively worse until it just would not light at all. I replaced the thermocouple with a Honeywell universal thermocouple that I got at Home Depot - that did not solve the problem. I'm very handy, so I decided instead of going through warranty service and having to wait three or four days for replacement parts, I'd buy a new gas valve at Lowes and try that. It cost $54.00 and it worked. By the way, I put the original thermocouple back in and the pilot light stays lit - it was definitely the gas valve and not the thermocouple in my case. It was a real pain to do since I had to drain the tank, but it only took about three hours total. From what I've read, these things last anywhere between six months and two years. That's ridiculous, but at least I have hot water now. If you are reading this because you are considering purchasing a Lowes hot water heater, DON'T!!! I started my search for a replacement gas valve at Home Depot, but they don't stock them. Lowes had 8 on the shelf. That tells you something right there - the water heaters Home Depot stocks don't need to have the gas valves replaced before the tank wears out - there's no demand for the valves so Home Depot doesn't stock them. Lowes probably sells 8 of them a week - all the boxes were shiny and new, not dirty and dusty like some items get when they sit around in home improvement stores.
Nov 11, 2008 | Water Heaters
Bosch aquastar 125b ng
Replace the thermocouple.
Thats the flame sensor.
If the gas valve is not sensing flame it will not stay lit.
T-couple's are about 9 bucks.
Nov 06, 2008 | Bosch AquaStar 2400ES-NG
Water Heaters Logo
71 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
80stech
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
