Question about Goodmans W280NS Television
My goodmans LD3755HD keeps switching itself onto standby and then back on again and just keeps doing this. Any solution and is it worth repairing ?
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. In your case, most likely the power section.
If this is the case, then absolutely it's worth repairing !
Any caps in these (or any) sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 28, 2011
Testimonial: "Fast and great answer, Thank you"
Elonex tv keeps going onto standby, take about 10-15 goes to work.
Sounds like you may have some capacitors going bad. If it is a high end TV it may pay you to take it to a repair shop.
Nov 25, 2013 | Computers & Internet
Tv switched itself onto standby and now will not turn back on. tried unplugging it and plugging it back in but it still won't come off standby. when you press the button on the remote it goes green for a...
unit seems to go into protect mode.Theres very little that can be done..There is good chance unit needs to be checked at a repair shop.Try to find one that is authorized for your particular brand if possible
Aug 05, 2009 | Televison & Video
Goodmand 42'' TV turns itself off
Check to see it your TV has a timer and it was accidentally touched to activate. Good luck.
Jul 04, 2009 | Televison & Video
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
We have a Hitachi C28W1TN, which is just under 10 years old that has recently started switching itself off. It goes onto standby by itself and when we switch it back on, it instantly does it again. At...
It's been a while since this post, but I may have had a similar problem with my Hitachi. With no reason it would switching on and off randomly. The problem was with a solder joint on main relay - it was cracked and would not keep the coil powered so i kept flickering on/off. This relay is located on the front of pcb, between high voltage area and the switch and on my tv it is blue. Check all four joints and apply some new solder onto them. Make sure the tv is not connected to mains ;-) Hope this helps
Oct 26, 2008 | Televison & Video
Goodmans ld 26022
you probably have a short, as the security switch is turning off tv by itself for safety reasons.
Apr 22, 2008 | Goodmans W280NS Television
Goodmans GTV30W2LCD Sound with no picture, screen flashes up at switch on then again goes blank.
mine has just done the same thing, i had someone look at it and he said the picture had gone. its not worth repairing it as it cost more than the tv is worth. your better off buying a new tv.sorry.
Apr 15, 2008 | Televison & Video
Sharp 34" TV
Why shouldn't it be worth fixing? It's only 4 years old, my own TV is 15yo, I fixed it twice but it's still kick'n! You have a problem in the power supply, do you have electronic's know how? And test equipment? Soldering equipment? If so we could walk you through it, If not A repair man should only cost 80 to 100 to fix it.
Aug 13, 2007 | Sharp 32C-240 32" TV
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
329 people viewed this question
Top Goodmans Televison & Video Experts
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
