Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper feed problem, error 3 - Canon PIXMA MP160 All-In-One InkJet Printer
  • 310 Answers
E3 means paper jam,you need to unzip the printer to look at the paper sensor,not be skipped or broken.If i have been useful please give me a vote :).Thanks
Posted on Mar 28, 2011
Epson wf-2530 printer error see your documentation
Turn the printer unit ON
2. Pull the power plug from the back side of it
3. wait 1 min
4. Plug unit back in
5. wait 3 full minutes
6. try to print does the error still exist? If yes continue below
Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away.
If you continue to experience problems, PLEASE RESPOND TO ME
Dec 16, 2013 | Epson WorkForce Office Equipment &...
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
Our alarm and green power lights are blinking and LED is showing E 2 3. Any ideas?
This error E2,3 or Error 6000 from your computer; means that there is a paper feed error. it can be caused by a faulty paper feed motor, or a dirty timing disk film. to solve this problem check the paper load section, look inside is there any foreing body that block the paper feed roller.
Dec 09, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Kodak easy share printer dock series 3 faults
got same error, took the clear cover off the paper cartridge and kinda' force fed the paper thru. To my surprise...it worked.
Jul 02, 2009 | Kodak Office Equipment & Supplies
When i turn it(canon MP780)on, i see a error (##357). How can i fix it?
The service manual says this for ##357:
ASF paper feed (AP) position error.
AND ALSO:
##357 ASF paper feed (AP) position error
Cause: An error occurs at the AP positioning in the ASF (Auto Sheet Feeder) unit.
Solution: (1) To reboot, press [OK] button or turn off and then on the power.
(2) Replace the SHEET FEED ***’Y.
(3) Replace the SPCNT board.
Apr 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I865 flashing 3 times
That's a "paper jam" error that can be fixed by removing all paper and pressing the resume/cancel button. Then replace the paper in the feed chute.
The printer can straighten out a crooked feed to a very limited degree. The photo feeder attachment can interfere with a really full 8x11 feed. The i860 is very susceptible to overfilling the 8 1/2 x11 feeder without notice until you try to print. I usually remove the photo feeder until I need to print photos, and keep the regular paper feeder no more than 3/4 full. I pull out the regular paper when printing photos.
Feb 24, 2009 | Canon i860 InkJet Photo Printer
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
PIXMA MP150 => it says E-2-3... Please HELP!!
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer: CANNON Printers MP150/MP160 ERROR CODE E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
Oct 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
64 people viewed this question
old marine
old marine
