Question about LG Dryers
My "temperature" indicator will not
  • tina_thomson Mar 28, 2011
    It is a gas dryer and we did just blow out the entire lint tube within the last 6 months. However, we will do it again. Since we are both currently at work, it will not be today. Will respond maybe tomorrow.
    Thank you for responding.
  • LG Master
  • 2,605 Answers
Hello, Welcome to FixYa, This is typically a problem associated with blocked or obstructed venting...On certain modeld, especially if it functions on "time dry" but not "auto-cycles". If it is an electric dryer and not Gas, remove the vent hose and run a cycle and observe the performance. However, some models have "preset" settings and cannot be changed aside from selecting Normal, Perm Press, Delicate etc. Let me know how it works and we can go from there. please provide a complete model number when you reply and confirm it is indeed an LG or not. Regards, Macmarkus :)
Posted on Mar 28, 2011
  • Mark MacDonald
    Mark MacDonald Mar 28, 2011
    Great got it, gas, thank you for the reply. It would be very helpful if you could provide the entire model number after you check the venting. I'd suggest you try cleaning the lint screen under soap & hot water as well.
    Regards,
    Macmarkus :)
Cooking a 6lb beef tenderloin to medium in oven
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill or oven... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. The lower the cooking temperature, the more evenly the roast will cook. 300 degrees will take awhile but the outcome will be excellent. You can Google roasting temps to give you a general idea, but if you use a recipe time, you will overcook or undercook your roast, probably, 60% of the time. Probe thermometers are cheap and reliable.
Dec 24, 2017 | Grilling
Heater has developed an annoying "roar" . What could be the cause?
The roar is from what is technically called a "Cold Burner". This occurs when you turn the burner in extremely cold weather. When this occurs, immediately turn the burner OFF, wait 30 seconds and slowly turn the burner back ON to the lowest setting, before turning it to medium or high.
The above should solve the problem. If it doesn't, it's and indicator that the regulator on the outside of the house on the propane is frozen. It can be thawed by wrapping a bath towel soaked in hot water around the regulator. It only takes a couple of minutes to thaw and the gas will flow as it should. Once it's flowing, it shouldn't freeze again, unless the tank remains in the shade during most of the daylight hours.
Hope this helped you and thanks for choosing FixYa.
Sep 05, 2011 | Vanguard International Infra Red - Medium...
2004 Cadillac cts transmission slip
in reverse or forward gears??
Jul 29, 2011 | 2004 Cadillac CTS
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
Can not get temp. below +10 f
That is a Medium Temperature compressor, not Low.
May 08, 2009 | KitchenAid Refrigerators
1995 lincoln town car heater
the door opening & closing on Max a/c is the inside/outside air intake door.
The temp blend door is the one you are concernd about. It says you have to remove instrument panel for access. ouch!!!
A/C Electronic Door Actuator Motor
The A/C electronic door actuator motor (19E616) is located on top of the A/C evaporator core housing assembly.
  • Its function is to move the A/C air temperature control door on command from the control assembly.
  • The A/C electronic door actuator motor contains a reversible electric motor and a potentiometer. The potentiometer wiper is connected to the actuator output shaft and moves with the output shaft to indicate the position of the A/C air temperature control door.
  • Battery voltage is applied to the ends of the potentiometer. The voltage available at the wiper indicates the position of the potentiometer. The actuator wiper voltage is sent to the control module and matched with the wiper voltage of the module potentiometer. The printed circuit board then drives the actuator motor in the direction necessary to make the actuator wiper voltage agree with the control module wiper voltage.
Dec 27, 2008 | 1995 Lincoln Town Car
Dryers Logo
43 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
