Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
Have a 3 year old 42'' Toro Zero Turn never had a problem. Was cutting grass and it died. Will not start, no fire and does not seem as if it is getting fuel ? Does it have a fuel pump or could it be something else?
    Novelist:
  • 111 Answers
That unit has a fuel solenoid that is attached to the carburetor bowl. Over time this solenoid can act up at odd times. You can take off the air filter cover and manually choke the unit and see if it will start up again. I would take it in to your nearest TORO dealer. On the website it has a dealer locator to find the closest one to your zip code.
Posted on Mar 31, 2011
Runs good until hot chokes itself out or runs out of fuel engine reavs high then for 3 or 4 times then cuts off
sounds like the coil is breaking down at high temperature. make sure the engine is not covered with grass clipping and dirt. replace the coil. i think this will solve your problem
Mar 14, 2016 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro z420
you have to adjust your tracking. Your manual tells you how to do this
Jul 23, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
I have had the mower for about a year. Since I have owned the mower it leaves a trail of grass beneath the center of the deck. I have taken it to a toro dealer to check out the blades and deck and they...
Sharpen the blades,very sharp,and lift the deck one notch from where you normally cut.Some times the blades will get dinged,or the ends of the blades will dull.
May 17, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 42 " Zero Turn; In tall grass and even in moderate grass it is leaving a double strip of uncut grass, that lines up with the division between the centre blade and both outsice blades, resulting in...
Your blades may be erroded on the edges? Or the center blade hub might be damaged or worn.
good time to inspect all the blades and spindles for wear or damage.
Jun 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Why does the mower blow out chuncks of grass, i am not cutting to low? ive only usewd it 22 times
1. Sharpen the blades
2. Cut when the grass is dry
3. Ensure the belt to the blades is not slipping.
4. Clean the underside of the deck after each use, use a scraper if you must but keep the buildup to a minimum
5. Run the throttle wide open during cutting
Jun 16, 2010 | Toro 42'' Zero Turn Lawn Mower Trailer...
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
472 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
