Question about HP Pavilion a350n PC Desktop
I'm working on an HP Pavilion a305n with a replaced hard drive, power supply, and DVD/RW. All other components are factory default. I've copied the recovery disks to the new hard drive and tried running the recovery to the factory default installation - including making sure the BIOS was set to the default as well - and it continues to fail at ~34 minutes. I believe this is the point where I am to name the PC, but the video is pixelated to the point where the PC locks up and does not respond. When you restart, and it runs through recovery again, it gets to the same point and continues to lock up. Replaced the hard drive with a new hard drive, and the exact same response. Tried running a fresh copy of XP Professional and the exact same response. Tried running a fresh copy of XP Home and the exact same response. Any recommendations would be very helpful.
    Master:
  • 362 Answers
Hello, not sure if this helps, but if you're using a usb-connected keyboard + mouse, then try using directly-connected ps2 kbd and mouse. Regards, nicam49
Posted on Mar 28, 2011
I put new in power supply and went power on my computer and it would not turn on
If the computer was working before you changed the power supply then likely you have not connected all the header wires properly. Check your wiring again. If you replaced the power supply because the computer was not working, then you may have an issue other than power supply, such as a bad motherboard.
Mar 15, 2015 | HP Pavilion Slimline s5-1414 Core i3-2130...
Freecom Classic SL hard drive stopped working
Probable reason for failure of a disk is power, if the power is adequate may be some of its components like inductor, diodes in series with the power line are opened, check for any burn marks on the pcb
Jul 14, 2010 | Freecom Classic (22095) (22095)...
Problems with video HP Pavilion ZD7000
memory problem, screen frozen or something disturbing is on block(Like drives) My be the memory.
Jan 03, 2010 | HP 336084-6C0 - HP Pavilion zd7000...
My HP a420n won't start after replacing cd-rw drive
Please try to remove all the connections from your computer and also connections inside the motherboard, the power cord for your hard drives and also the power cord from the power supply to your motherboard.After that, remove the memory and clean the pin by using an eraser of the pencil. And then insert again the memory stick and connect all the connections from the power supply to motherboard and everything. Lastly reset your bios and put it back to normal again. Hope this would help. Thanks..
Oct 22, 2009 | Computers & Internet
HP Pavillion DV8000 Factory Restore
HP.Support.drivers put your model number in the search box, choose drivers - software. All the files that are compatible with your computer are there for the downloading and all is free.
Sep 09, 2009 | HP Pavilion dv8000z Notebook
Format/restore computer to factory settings
Press F11 at system startup to get to the NEC recovery menu. From there, you can restore your factory settings. However, a "destructive" recovery will wipe the hard drive, including your personal files. Best to back those up first before performing the recovery.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP 419320-001 - HP Pavilion dv4000 Series...
Hoow to install a dv2000 hp pavilion dvd rw drive (internal)
Remove the Phillips PM2.5x7.0 screw (1) that secures the optical drive to the computer
Insert a thin tool, such as a paper clip, into the media tray release hole (2). (The optical drive media tray release from the optical drive)
Use the media tray frame to slide the optical drive (3) to the left.
Remove the optical drive.
ce642a5.jpg You can download the complete manual here:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Jul 22, 2008 | Compaq Pavilion ZT3280US Notebook
Hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion a350n PC Desktop Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
