Question about Vacuums
I have a roomba 551. Have cleaned and removed every bit of dirt and hair off it bu the brush cage won't close when the larger bush is put in. The cage will only click locked on one side, and the other side keeps hitting the brush and won't close. It's almost as if the bursh itself is not even, but this doesn't seem to be the case either. I've even tried removing the yellow rings, but makes no difference. Occasionally it runs fine, but most of the time the roomba just hobbles and clacks as it goes and stops after a few minutes and says to "clean brushes" but the brushes are clean. Any good answers would be appreciated!
Hi, had the same problem, it was like the main brush no longer fit into it's slot, so the brush cage would not latch. I discovered that the yellow bearing tip on the main brush twists off, and inside I found a lot of hair twisted around the pin. There was so much hair that it had forced the bearing tip to unscrew, making the brush too long to fit in the slot. After I pulled out the hair, the bearing screwed back on perfectly, and it works great now.
Posted on Dec 04, 2011
  • 1 more comment
  • Amanda Shaffer
    Amanda Shaffer Jan 30, 2012
    Thank you! This worked like a charm!
  • Timothy Boutillier
    Timothy Boutillier Jan 14, 2014
    Thank you very much. Worked perfectly!
  • Anonymous Apr 10, 2017
    Yay! I've been looking for this solution forever. Couldn't understand why the lid wouldn't shut. iRobot even sent me a new cage cover (great customer service, btw). Thank you!!!!
My Roomba 560 is making a clunking noise when it is on and it keeps stopping saying that I need to clean the brushes. I've thoroughly cleaned the brushes and I've cleaned lint from other small crevices...
I'm having the same problem with my 560 after a day of use. For me, it's caused by the little yellow spacer that's clipped onto each side of the bristly brush. When the brush assembly is closed, it wedges rather tightly next to that yellow spacer on the left. This causes a lot of friction and heat, and mine's worn away quite a bit already.
My solution was to just unclip that spacer and leave it off. It's probably not an ideal long-term solution, because dirt and hair will be more likely to get into the drivetrain. But at least it works now.
Another thing that these roombas apparently suffer from is clogged up gears. If you aren't having the same problem as me, you could try the instructions here to clean the gears:
http://www.robotreviews.com/wiki/cleaning
Hope that helps!
Sep 13, 2010 | iRobot Roomba 560 Robotic Vacuum
Irobot stops after a few minutes and says plaes
soooo, what is not understood here ?
turn it over, open brushes cage, take each brush out and clean it.
In addition, also clean the sides from any dirt/hair that may stuck in its pivots.
good luck
Avi
Apr 07, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
Bin barely fills. Lots of dog hair between brushes and bin, and is now dropping hair balls as it goes around the house
This is why Roomba recommends a thorough clean of your carpet with a standard vac prior to using your mini vac. Once all heavy debris has been removed, the roomba will maintain that state of clean. If you have that much dog hair, you cant expect such a small roller, brush and dustbin to keep up. sounds like you need the dirt dog instead. It is capable of handling heavier demand areas. Or the
iRobot Roomba® 562 Pet Series
Feb 17, 2010 | iRobot 560 Roomba Vacuuming Robot, Black...
Runs for awhile then says error 2 please remove and clean roomba's brushes i do then runs for awhile and says same thing no dirt on brushes?
I had the same problem. You must clean this parts and inside this parts:
Remove hair with cleaning tool
Remove Roomba's brush bearings
Clean Roomba's brush bearings with cleaning tool
Dec 29, 2009 | iRobot Roomba 560 Robotic Vacuum
My roomba 560 has brushes that spin one rotation then stop then you hear a click and they rotate one rotation stop over and over. I took compleatly appart cleaned, lubed, and inspected all looked good?
I thought my brushes were clean, but here is what I discovered, and it fixed my Roomba.
The yellow bearing on the opposite end the brush rollers from the gearbox will pull off the shaft. These bearings spun freely and looked clean, but when I pulled them off there was hair and junk between the end of the brush and the back of the bearing. When installed in the Roomba this gook warms up and gets sticky causing friction and stopping the brush from spinning.
Use a toothpick to pull this stuff out and the brushes spin free again. I was very frustrated, and this fixed it, works like new again.
Mar 16, 2009 | iRobot Roomba 560 Robotic Vacuum
IRobot not picking up dirt
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Remove the Yellow connectors on the end of the brushes and clean around the pin well. If there is too much there, the roomba thinks there is something stuck and goes into clear mode (as if there is a chord stuck).
Dec 26, 2008 | iRobot Roomba 560 Robotic Vacuum
Vacuums Logo
804 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
