Question about Bose Companion 5 Multimedia Speaker System (3-Piece)
I live in India and the power supply here is 220v and I bought bose companion 5 series from US which works at 110v. I bought a step down converter which could take upto 1000 watts of power and i hooked it up to the product. After 4 mins the system had smoke all over and threw out some liquid. No clue what is the problem
  • 66 Answers
To be honest, it sounds as if the system was destroyed . I'm no Electronics Engineer , but smoke and liquid should not be coming out of speakers.
Posted on Mar 28, 2011
I just bought a computer speaker but it's 110v and my computer is 220v. can i plug the speaker to the computer without damaging the speakers?
Hi ,
If it says it needs a AC 110V connection , you will fry at least the sub . Don't do it ! Connect the device to an AC 220 / 110 V transformer you can find on the net or in all specialized retail shops .
Best regards
Feb 03, 2011 | Bose Companion 5 Multimedia Speaker System...
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Apr 04, 2010 | Bose Companion 5 Multimedia Speaker System...
Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
Companion 3 problem
It is not the pod that isn't working, a 220v power supply would overload the circuitry in the subwoofer. And since the damage is done, a step down converter would be no help at this point. I would take it to a electronic repair shop and have them take a look at it.
Aug 11, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Problems
email support@bose.com or contact a Bose Support Specialist in Germany; or call US support at 1-800-367-4008. Something very odd is happening here. You are using the same laptop, correct? If not, let me know, as there are some things to try. If Bose has a solution, I'd love to hear it.
Mar 19, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Down!
While I can not second guess your technician, perhaps the problem may not be that severe. The Bose Companion 5 is only on standby when plug (having no power switch) and therefore the power supply circuitry is the only one working. Chances are it will be only the +5VDC logic supply that is really turned on at that instant. All others would be OFF hence my belief that the problem may be limited to the PSU and/or part of the logic board. Perhaps you can suggest to your tech to test the logic board (motherboard) using an external +5 supply. All others can be be tested and repaired using component replacement.
Should you not be comfortable going this route, perhaps you best bet would then be to get in touch with Bose or their local representative.
You can try looking over the country here and the page will display a Bose contact information. Say the Philippines would be:
Eleksis Marketing Corporation
Unit 206 Fox Square Building
53 Connecticut Street
Northeast Greenhills
San Juan City, Metro Manila, 1500, Philippines
Tel-1: 632 724-9566
Tel-2: 632 724-7527
Fax: 632 724-0176
Email: Click here to send them an email
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
514 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
