Question about Atari Duel Masters for PlayStation 2
While running duel masters ps2 in pc with pcsx2 how to switch to controls of player 2 or change them or about cross and scrolling keys.
When i run pcsx2 it says your pixel shader is too low
Your video is not capable of handling the required pixel shader to run pcsx2 for emulating PS2 games.
You're lucky if your video card can be upgraded. If not, you better look for new video card. I believe PS2 emulators requires at least version 2 pixel shader.
Feb 12, 2010 | Connectix Virtual Game Station 1.4...
Can I run Playstation 2 games on my PC without a PS2 console.
No, but you can buy PC games that our the same as Ps2 or 3 games
Dec 03, 2009 | Sony PlayStation 2 (PS2) Console
I want to know which software that can play ps2 on computer
http://www.pcsx2.net/
Its a emulator for the pc to play ps2 games
here is the guide on how to set it up.
http://forums.pcsx2.net/thread-2298.html
Regards
Jul 21, 2009 | Sony PlayStation 2 (PS2) Console
How to install wwe smackdown vs raw 2009 ps2 game on pc
For PS2 emulation: You can play by using PCSX2 0.9.5 latest version, but your pc must be strong enough to hold it. You can download it at www.pcsx2.net.
You need the game to use the emulator. Also understand you need a powerful computer to run these games on your computer.
Apr 26, 2009 | THQ Video Game Consoles & Games
Can i play pcsx2 in my computer without having any ps2 controller
yes you can you the keyboard to play but in my experience the control pads work better, they are real cheap online too if you look around, amazon is good.
Apr 05, 2009 | Sony PlayStation 2 (PS2) Console
Question regarding playing a game of ps2 on pc
download a software called pcsx2,search google ,make sure to check the compatibility list of games, not all games work perfectly.
u also need to get the ps2 bios search google for those too.
add them to the bios directory(in the pcsx2 installation folder)
and follow instruction on the pcsx2 site to configure the program
Feb 02, 2009 | Sony PlayStation 2 (PS2) Console
Run ps2 games on pc
Download the PS2 emulator software.....called PCSX2......of course u need 2 have a PC with a good config to play PS2 games
PCSX2 ------- ...download it from
http://www.pcsx2.net/downloads.php
This one is a very good video tutorial,
http://youtube.com/watch?v=eqXp65lW-SE
Recommended config:
CPU: core2duo 2.66Ghz Wolfdale or higher
RAM: 1GB
GPU : nvidia 8600 GT or higher
Cheers
Aug 03, 2008 | Sony PlayStation 2 (PS2) Console
PLAY PS2 GAMES ON PC
Ok, you want a full procedure here it is. First of all if your computer does not meet the following specs stop reading cuz you'll be wasting your time trying to get it to work and will be very disappointed by the quality of game play:
Minimal Specs:
AMD 64 or Intel Pentium 4 (VM Build will not work with non SSE2 CPU's)
512MB of RAM
Pixel Shader 2.0 supporting card
Recommended Specs: (For reasonable performance in many games, but not all)
AMD64 X2 or Intel Conroe E6600+ (Multi Threading is supported in PCSX2)
512-1024MB of RAM (more RAM allows for VM mode to be stable)
Pixel Shader 2.0 supporting card (recommended GeForce 6600-8800 or equivalent ATi card)
Possible Ideal Specs:
64bit OS such as Vista or winXP64, to allow for future support of 64bit recompilers.
Future AMD or Intel Quad Coremaybe needed, but currently the support of 4 threads is not handled byPCSX2, and the effect of threading out EE / VU is not yet known.
We don't forsee you requiring a GPU more powerful than the current generation of cards, up to and including the nVidia GeForce 8800.
Also note, if if have just a standard AMD Athlon (non64) don't even bother trying to run this emulator. It does work but is very very slow.
If you meet at the very least the minimum specs go here and download PCSX2 Binary. .::CLICK HERE::.
This is the BEST PS2 emulator currently on the net. There is NONE better.
Next: as with any emulator you need a BIOS in order to use it. There are several methods to getting a PS2 BIOS. You can google "PS2 BIOS download" or check torrent sites like this one .::HERE::.and do a search for "PS2 BIOS". At any rate, get 1 or many BIOS(one for each different area ex. Japan, US, Europe)
Next: Un-7zip the PCSX2 7zip. Take the BIOS.bin files you downloaded and place them all in the folder, "bios" in the PCSX2 folders you unzipped.
Next: You'll notice two icons that look the same one is called pcsx2.exe and one is called pcsx2t.exe. I have had no luck getting anything to play worth a **** on pcsx2.exe. I use pcsx2t.exe. According to the person who made this program, pcsx2.exe is a faster emulator version, but he says that AMD people have had better luck using pcsx2t.exe. So, if your computer has an AMD processor try the pcsx2t.exe first. But keep what I said in mind cuz you may have to use the other one instead. In either case, choose one and run it.
Next: When the program opens, it will have to be configured. Look at the top of the program and click the, "config" menu option. Next click the, "configure" menu option. You are now faced with several configuration options. I'm not even going to bother explaining what each option does, go .::HERE::. it explains what everything does. 9 times out of 10 when pcsx2 won't work, it's cuz of a bad configuration. SO MAKE SURE YOU READ THAT WHOLE PAGE.
As you can see there two ways you can load a game. Either by turning the game itself into an ISO or from using your DVD-ROM drive.
As far as controlers go, you can purchase USB PS2 look alikes from most computer stores. You can also get PS2 to USB converters that you can plug directly into your computer. And there is even a SIAXIS driver floating around on the internet that will run a PS3 controler as if it was a standard computer game controler. If you don't have money for a controler or what not just use the ZeroPAD option under, "First Controler" and start binding keyboard keys to assigned slots.
As with any emulator nothing is perfect and this will not play every single PS2 game out on the market. However, this is the most current emulator in production atm and is the furthest along. When you get everything up and running you'll want to look ..::HERE::. at the compatibility list to make sure your game is registered to even work with this emulator.
Hope that helps,
L8er
May 22, 2008 | Sony PlayStation 2 (PS2) Console
How does I run the ps2 games on pc ?
http://www.emulator-zone.com/doc.php/ps2/ There are 3 different emulators there. I haven't tried them, so I can't say how well they work, but if your hardware can handle it, one of those should play your PS2 games.
Sep 04, 2007 | Sony PlayStation 2 (PS2) Console
Atari Duel Masters for PlayStation 2 Logo
179 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
James Wishart
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
