Question about Heavy Machinery
Could you please supply part # for blades for chipper model # 11087? Thank you...
Cutting toolTool Masters is the leading innovator and manufacturer of a wide range of precison Cutting Tools.
Posted on Mar 29, 2011
Chipper model sears 797851 cant get chipper blade screws out to sharpen
The first thing I would do is to spray the screws with a penetrating oil like PB Blaster. Let it set a while and try again.
Sep 16, 2015 | Sears Heavy Machinery
Need Discharge Screen for my Troy-Bilt Supper Tomahawk 8HP chipper/shredder Model #11087 and Part # W20501075 purchased 3-1988 from Garden Way Inc. Thanks for your help
This will take a little research but do a search for "mower forums" on Google, Bing or Yahoo. Ask your question over there and you just may find someone with one to sell.
Two other places to try. First, do a "saved search" on eBay and wait for one to come up. Or, go to eBay and search for Troy Bilt Chipper parts (or shredder) Look at the sellers and you will find some sellers who sell a lot of parts. Ask them if they would know where to find your part.
Second, on Craigslist post what you are looking for in the "items wanted" section.
Jan 06, 2011 | Troy Heavy Machinery
Need replacement chipper blades for 5HP tomahawk chipper. Older model distributed by GardenWay. Model # 47255. Probably pre 2001 bankruptcy action. Would settle for specifications (L,W,Thkness) and type of...
This is the only source that I know of for the older chipper blades. Problem is you need to know the dimensions.
http://www.wesspur.com/chipper-knives/chipper-knives.html
There is an MTD one that is for troy-bilt but was not able to match it up with your unit due to pub issues here on my end: PN is MTD 1901782MA
I recommend you contact these folks to get it sorted out:
http://www.wesspur.com/contact-wesspur.html
Hope this got you pointed in the right direction.
Thanks for using FixYa.
Kelly
Jun 26, 2010 | Troy-Bilt ChipperShredder
How do you change the cutter blade on the TB Chipper?
I just did one!
There are two opposing threaded holes next to the shaft.
Screw in bolts and use a wheel or gear puller to remove.
You can use a socket that fits in the center bore for an extention of your gear puller.
auttozone or ayto supply rents for free w/deposit
May 22, 2010 | Troy-Bilt Chipper Shredder
I have a troy bilt mulcher model 47057 serial number 470570100839. We need to buy some more blades etc where would be the place to buy the parts from
I would check with an MTD dealer. I look online and found a site for the chipper blades and they wanted $40.00 USD for each. It may be worth your time to take the other ones out and get them sharpened.
Good Day.
Oct 12, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
I need a owners manual for a 10 hp chipper schreddermodel 24a464g729 serial no. 1io14g4o175 i think i may need blades
Go on line to " PartsTree.com" Start your search by clicking on MTD. Go to chipper/shredders, and fine your Model number, It's listed. In the search window- type in chipper blade. Also, on the drawing schematic of the machine, the blades are # 31 in the list of parts. I looked up the 2005 model. There are are few years with the same Model #.
Jul 14, 2009 | Mtd Products Yard Machines 158CC Tiller
Ineed to sharpen my wood chipper blades on my
It takes me about 5 minutes to Remove, Sharpen, and Re-install my chipper blade for my Bolens mc2500. First, If your using a screen or rollers in the discharge, then remove them. Look underneath, and you will see the thick flywheel. Make sure the spark pug wire is disconnected, then slowly turn the flywheel by hand until you see the two hex head bolts that hold the chipper blade to the flywheel. Also remember which way you take it off, so it goes back together the same way. using an open end or combination wrench remove the two hex bolts. Now to sharpen, I use a medium/ coarse honing tool made for lawnmower blades. I clamp the blade to the top edge of my Bolens with a pair of visegrips, then a little oil, and the sharpening tool, and I'm done sharpening in about 2 minutes, and then re-installing, reversing the removel process. I hope this helps.
Apr 29, 2009 | Garden
New dado set understand the shimms and chipper work
The shims are placed between the blades and chippers in a stack. they are used to make very small adjustments to the final dado width... So usually you set up your dado set for a specific width of cut according to your blade chart, then make a test cut... If you need to widen the cut very slightly, add some shims in between the blades as required to get a good fit on whatever material you are joining or putting into the dado etc.
Hope that makes sense!
Please rate this solution on FixYa!
Apr 12, 2009 | Delta 35 7670 8" Stacked Dado Set
My chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Mar 31, 2009 | Heavy Machinery
Heavy Machinery Logo
54 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
