Fridgidaire FWT 449GFS1 door locking mechanism seems to be broken. model numember is XC91 705565 I could try to change the mechanism ( its the one inside the machine with the various wires coming to it) but I do not know which part to order... thank you
  • 641 Answers
SOURCE: Broken interior Door catch
You should open machine's upper panel (release 2 screws in the machine's back and slide the cover out) and then you will have an access to it. You should buy a new door catch and replace the broken one. Be aware that you should disconnect machine's power cable before doing it. Good luck
Posted on May 09, 2006
  • 641 Answers
SOURCE: Interior Door catch broken
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
SOURCE: whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Posted on Jul 03, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
My 2000 Ford Explorer drivers side door will not unlock with the key fob, the number strip on the door, or with the key in the key slot. All the other doors will unlock using the key fob. What is th
Not sure if lock has solenoid or electric motor, but either way, can you hear clicks or any prominent sounds from the door whilst trying to unlock it? you may need to put your ear on the door, if no sound, then wiring needs to be checked, then motor or solenoid, if you do hear similar sounds to the other door then the mechanical part of the lock mechanism has failed and may require a kit or replacement.
Sep 29, 2014 | 2000 Ford Explorer
Tip
FRIDGIDAIRE FRONT LOAD WASHER DOOR LOCK
THIS FRONT LOAD WASHER HAS AN ELECTRONIC SWITCH THAT SNAPS INTO THE LOCK MECHANISM. MINE POPPED OUT OF THE 2 CLIPS THAT HELD IT IN PLACE, SO WHEN I CLOSED THE DOOR, THE LOCK LIGHT DID NOT LIGHT AND THE DOOR DID NOT LOCK. HAD ALL KINDS OF ADVICE THAT DIDN'T WORK. UNPLUG THE WASHER, REMOVE O RING AROUND RUBBER BOOT. REMOVE THE FRONT PART OF THE BOOT. THEN YOU JUST REMOVE THE LOCK MECHANISMS, 2 SCREWS IN THE FRONT. PULL THE LOCK MECHANISM HOUSING TO THE SIDE, BE CAREFUL OF THE CONNECTED WIRES, THEN LOOK WITH A FLASHLIGHT. IF THE SMALL SWITCH BOX IS OUT OF PLACE, THEN POP IT BACK IN. THIS PROBLEM STARTED WHEN I WAS CLOSING THE DOOR TOO HARD AND QUICKLY. SO BE GENTLE WHEN CLOSING YOUR DOOR. THE ARM THAT LIFTS TO HIT THE SWITCH THAT TURNS THE DOOR LOCK LIGHT ON AND LOCKS THE DOOR, IS PLASTIC.
on Sep 17, 2013 | Frigidaire Washing Machines
99 disco 2 door lock problem. front passenger door will not lock or unlock with key in drivers door or central locking switch on dashboard. replaced door lock/ actuator mechanism but no change. key fob...
is the locking system mechanical,electrical,vacuum????. If mechanical:linkage came loose?,if electrical:loose or broken wire?,if vacuum:vacuum line punctured ,pinched or broken??, Don't buy parts unless you pinpoint the problem. Alberto
Feb 12, 2014 | Cars & Trucks
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
I am getting the code dl and F on my whirlpool duet washer model # GHW9150WO
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Thank you
Jul 17, 2010 | Whirlpool Washing Machines
My driver side door wont close. the handles seem to do nothing. any advice?
the door lock mechanism has a broken spring internally .door lock has to be replaced.
Jan 15, 2010 | 1998 Ford Windstar
Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Feb 15, 2009 | KitchenAid KUDR25 Dishwasher
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
WHIRLPOOL DUET WASHER 9150 DOOR LOCK DOES NOT UNLOCK
Door Lock Error
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
replace door lock and ccu sorry
Jul 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
