Question about Moen & One Handle Tub & Shower Faucet
Moen single handle tub/shower valve . No hot water, cold OK. Nearby shower same vlave works fine. Cartridge "looks" OK. What next,
    Genius:
  • 1,015 Answers
Even if the cartridge looks good from the outside I have had them plug up internally with mineral deposits. I would remove cartridge and replace it.Hope this helps.Thank you
Posted on Mar 28, 2011
Why does moentrol bath valve give hot water pointed to "C" and vice versa?
Easy one.
Feel the pipes. The pipe on the right should be cold. If the pipes are correct, turn the cartridge 180 degrees.
Jan 20, 2013 | Moen & One Handle Tub & Shower Faucet
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Jan 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I have a single handle Moen faucet in my shower. It has not been used for a while , now that my kids are home and try to take a shower there is little hot water coming from the shower. The cold water...
probable that there is mineral deposit's,scale buildup,inside. pull cartridge and look in valve body,turn water on to it and flush valve body real good.possible model #1222-if it's posi temp ,#1225 for reg faucet
Jan 01, 2010 | Moen & One Handle Tub & Shower Faucet
Tub single handle ...no cold water, hot water fine, sink ok
rubber piece on caartridge may have become loose and is blocking water port.gonn'a haveto replace cartridge
Dec 16, 2009 | Moen & One Handle Tub & Shower Faucet
Moen one control shower faucet is leaking hot water
Try replacing the cartridge first.That's your best bit . Next would be the whole valve. Hopefully, it's just the cartridge.
Jul 04, 2009 | Moen & One Handle Tub & Shower Faucet
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Single handle moen bath fixture only lets out hot water
remove the cartridge and see if their is anything blocking the cold inlet.If you dont see any dirt than that means that the cartridge needs to be replaced
Jan 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Moen & One Handle Tub & Shower Faucet  Logo
191 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
