Question about Frigidaire FRS26R4C Side by Side Refrigerator
Got new fridge freezer last week and set dial at 4 but not very cold have to put up to no 7 but those that mean i am using more electrity and what is the correct setting it sould be at
  • 57 Answers
4-5. Is fan in freezer section running? Is fan in rear of unit running? Do the sides of unit feel hot to touch? This unit has a problem. Call for warranty service.
Posted on Mar 28, 2011
What settings do you recommend for the refrigerator and freezer/
fridge --around 4 ( should be at 5 degrees c and freezer around 6---minus 20 degrees c
for the fridge settings the numbers work down from hot --7 to zero --- 1 where as the freezer works from 1--- zero to minus to 7 really cold at -20
adjust each depending on the time the door is open and the frequency of the opening ---examples
if you find that lettuce is freezing at 4 and you are the only person using the door , put it up to 5 but if there a family and the door is continually being opened or held open while the minds are being made up , you may have to consider 2 or 3
Sep 18, 2016 | Amana Side-By-Side Refrigerator 26 cu. ft....
What cold setting should my fridge be on?
Put both dials on cold and wait 48 hours then adjust from there.
Aug 27, 2012 | Frigidaire Refrigerators
The freezer is working extra well but the fridge is not getting cold even though it's set at 7
Check that the vent opening inside the fridge is not blocked. Depending on the age, some of them now have a filter that needs to be changed periodically. RepairClinic.com or Sears sometimes are able to give you an answer over the phone as to what else to check.
Feb 04, 2018 | Amana ABB2223DES Stainless Steel Bottom...
I have a Maytag 3 door ,freezer on the bottom, for the last 3 years every few weeks the fridge looses its coldness and the freezer is ice cold also it it always on temperature 1, so I have to unplug it...
Either, the defrost timmer has had it, or the freezer defrost element has failed, the element is the most common cause of this type of problem. You have ice build-up in the freezer cores because it cant defrost, all frostfree units rely on cold air from the freezer to blow into the fridge, if the freezer cores become blocked, air can not pass to the fridge side. I bet you, if you left the unit off for 2 days to defrost totally,,,,with the doors open...then plugged it back in, it would work like new for 2 weeks.
Timmer or defrost element needs to be replaced...do not fall for the trick that the fridge mech. has to take it away, you tell him that this is the problem and you will save yourself ALOT of cash.
Dont forget to vote for the solution...regards Russ
Mar 08, 2011 | Maytag Freezer MQC2257BE
Fridge not keeping things cold enough
fridge coldest setting is 1
freezer warmest setting is 1
Dec 08, 2017 | Fisher and Paykel E522BLXEZ EZKleen...
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
May 12, 2010 | Refrigerators
I recently purchased a home. The kitchen has a
Firstly, the thermostats are usually calibrated at one elevation and where the fridge ends up may be above or below that so the number settings on the dial aren't that relevant. You should adjust the thermostat in increments then check the temperature after 24 hours, then adjust again if necessary. The fridge should be as close to 40 degrees F. as possible and the freezer about 26 degrees F. (if memory serves me). The heat you detected is the unit in defrost cycle and should be considered normal if intermittent and a problem if constant. There should be a switch to turn off and on the defrost feature if you determine it's a problem.
I hope this helps you and good luck.
Sep 03, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Frigidaire FRS26R4C Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
