Question about HP LaserJet 3050 All-In-One Printer
The HP Laserjet 3050 in our office does not feed the document through, it tries but you can just hear it turning. The printer contantly reads "document loaded" without anything in it. After a while of trying to feed the document through it stops and reads no document on the computer. Any thoughts?
  • 22 Answers
I haqve an all-in-one that I had problems with the automatic document feed quite frequently with. If you can get to the feed rollers that **** the pages in fairly easily, it is often a simple matter of cleaning these rollers with alcohol and a cotton swab thoroughly. They are often spongey so if you use water they will not dry easily, I cleaned mine on my HP G85 and it works like new now. I couldn't beleive the solution was so simple but believe me, this worked for me.
Posted on Apr 02, 2011
HP LaserJet 3050 All-In-One Printer blank pages after attempting to print second envelope from same document - turning off and back on solves temporarily
If the same fault occurs with different printers it is almost certainly caused by the document.
"...second envelope from same document" suggests you are using a mail-merger. Is that right?
What happens if you start again from scratch? Mke a new document and try to print it a a single entity, without using mail merge?
Feb 05, 2016 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 all in one
pls clean printer solenoid it wl solve
Nov 27, 2012 | HP Pick Up Roller Rm1-0885 for Laserjet...
Hp laserJet 3050 fax pulls all the pages at one time
The 'separation pad' needs to be cleaned or replaced.
It's a small rectangle piece of rubber at the entrance to the
automatic document feeder(ADF). It should be just under the feed roller.
A drop of isopropol alcohol on a lint free cloth should work.
Oct 11, 2011 | HP LaserJet 3050 All-In-One Printer
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
Hp 3050 scanning error message
Good day!Try to check the feeder if it has paper on it..then try on and off the printer until it holds normal status..
mastergani
Mar 29, 2010 | HP LaserJet 3050 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Scanner does not work message Waiting for PC
my hp laserjet 3050 prints but i need the driver to scan a document.
Apr 18, 2009 | HP LaserJet 3050 All-In-One Printer
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
The printer shows that a document is inserted and the HP toolbox shows the printer status as having a document inserted..then use the scan button on pc to scan it
Oct 18, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
