Question about Acer Aspire 9800 Notebook
Hard drive has been compressed and when i turn my computer on it comes up with press ctrl-I to enter conficuration facility but it wont let me in then another screen appears and says PXE-E61: media test failuure,check cable and PXE-MOF: exiting PXE ROM and then it doesnt do anything my computer is an aspire 9815WKHI serial number is LXAF60U023707007332300
    Master:
  • 362 Answers
Well, the PXE messages only mean your laptop can't find a LAN to boot from, so that's not relevant to your problem, though you may be able to disable 'network boot' from the bios set up, but it does mean your laptop can't find any bootable media. If I think of anything else, I'll post it. Regards, nicam49
Posted on Mar 28, 2011
How do i fix this problem:ZKQON IS COMPRESSED PRESS CTRL+ALT+DEL TO RESTART
Best thing to do is uncompress your hard drive, then get a new one with more space you can easily make an image of your drive then transfer it to the new drive, YOU will not lose anything.
http://www.pagestart.com/win7bckuprstrnhd072610.html How to move windows 7 to new or larger hard drive using Backup and Restore
Nov 28, 2014 | Acer Aspire 4736Z 4736G 4738ZG 4733Z...
Bootmgr missing toshiba
Which operating system >?
What type of computer Desktop or Laptop >?
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error.
also make sure you have set it boot from you hard drive in BIOS
Restart your computer and enter BIOS mode.
On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on.
Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it.
Once you've selected your desired options, continue to boot.
or
The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk.
When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done.
Put your hard-disk back in to your machine its ready..
w7
insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
it will work 100% only if you prompt at the same order
Hope this helps.
BOOTMGR Is Compressed
The Windows operating system allows you to compress the files on your drive to conserve disk space.
In some situations, this compression process will compress files required for the operating system to boot.
Files that are compressed must be decompressed prior to execution.
Since the operating system has not loaded, boot files cannot yet be decompressed.
In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear.
An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD.
Press a random key on your keyboard once you see the "Press any key..." message.
This interrupts booting from the hard drive and forces a boot from the Windows DVD.
Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below.
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx
File Compression and Decompression
Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog.
This opens a file browser on your screen.
Click the "Computer" icon, which is located on the left hand side of the screen.
This displays an icon for your disk drive.
Right-click your hard drive, and click "Properties.
" This opens a Local Disk Properties dialog.
Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button.
Select the "X" icon to close the file browser window.
This takes you back to the Install Windows dialog.
Press the "X" icon at the corner of the Install Windows dialog.
This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer.
Fix Bootmgr Is Missing in Windows XP
Open your anti-virus software program and run a full scan on your computer.
Delete all quarantined and infected files when the scan is complete.
Insert your Windows XP Install CD into your computer's CD/DVD-ROM drive.
Restart your computer.
Press the "R" button on your keyboard when the screen says "Welcome to Setup."
Type in the admin password when prompted.
Press "1" and then "Enter" to open the command prompt.
Type "fixboot" into the command prompt.
Press "Y" when a pop-up box appears, asking you for confirmation.
Restart your computer and you should be taken to your desktop.
Nov 12, 2013 | Toshiba Computers & Internet
Boot manager compressed press ctrl+alt+del
Causes of BOOTMGR Errors
or
w7
insert your OS CD
then type in exit
Hope this helps.
Aug 06, 2013 | Computers & Internet
BOOTMGR is compressed
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot. or The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk. When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done. Put your hard-disk back in to your machine its ready.. w7 insert your OS CD
then type in exit
it will work 100% only if you prompt at the same order Hope this helps. BOOTMGR Is Compressed b> The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
Jan 16, 2013 | Dell Computers & Internet
My bootmgr is copressed.
then type in exit
b>
Jan 15, 2013 | Dell Mini 910 Netbook
Compressed boot in win 7
boot the CD-Drive first. For more information please visit HERE.
Steps:
1.Insert the Windows 7 OS disc into your CD-drive and restart the computer.
2.Wait for the setup window to appear
3.Press Shift+F10 simultaneously to bring up Command Prompt
4.Type in Code: bootrec/fixboot then press enter
5.Last but not least type in Code: bootrec/fixmbr then press enter
Nov 19, 2011 | Compaq Presario 700 470024-192 Notebook
Please help!! my dell latitude d620 fails to boot displaying: YVFXP is compressed press Ctrl+Alt+Del to restart. When i do this it jus does the same thing.
Ifyou have compressed the hard disk drive using the Compress drive to save disk space option under the Propertiesmenu for your hard disk drive and have performed a non-destructive recovery ora system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved byfollowing these steps: 1. Insert the Windows XP CD drive onthe computer and restart the computer. 2. Press F12 when the computer firststarts, then select CD-ROM, click any key to boot into windows startup. 3. When you get to the install windowsXP screen: 4. Press Rto repair the Windows XP installation using Recovery Console. 5. Enter the appropriate number for theWINDOWS installation, for example, the WINDOWS installation could be listed as 3:C:\WINDOWS or 3: D:\WINDOWS . 6. If prompted, enter yourAdministrator password and press Enter . If there is no password, justpress Enter . 7. At the prompt, if the WINDOWSinstallation you selected in Step 4 was C:\WINDOWS, type: cdc:\ Or, if theWINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cdd:\ 8. At the prompt, type: attrib-c ntldr and thenpress Enter . 9. At the prompt, type: exit 10.Press the Enter key and immediately remove all discs or diskettes from thecomputer to allow the computer to restart.
Mar 05, 2011 | Dell Latitude D620 Notebook
How do i fix a disc error on my acer aspire
Make sure you do not have any devices plugged in to the computer like a USB flash drive or a MMC. Usually what you have to do about that is to drain the power of the computer. Turn it off, remove the battery, unplug the AC adapter and then press the power button for 5 secs. Turn it on using the AC adapter alone. if you still get the same message, You will have to physically open the back of your laptop and reseat the Hard drive. If it still wont correct the problem, restart you computer and either press f2 or delete to enter the BIOS page. check if the HDD is properly detected and try to reload the BIOS defaults. now if any of these wont work, call ACER and most probably your Hard Drive is bad.
Jun 12, 2010 | Acer Aspire 3680 Laptop
BOOTMGR is compressed press Ctrl+Alt+Del to restart
Insert Microsoft Windows Vista Installation Disc.
Press any key when it says "Press any key to boot from CD".
After that you should see "Windows is loading files..."
KEEP pressing F8/F9(can't rmb which, just press both alternately) while
the progress bar loads..... Dun let go until you reach "Advanced boot
information" where you should see Safe Mode, Safe Mode with Networking,
Last Good known configuration etc...., just select Safe Mode with
Networking(or Safe Mode/Safe Mode with Command Prompt) and press Enter.
Wait for the files to load and there should be "Safe Mode" on 4 corners
of your monitor.
Just be patient and wait. A windows would soon pop up and says "Install
Windows". Don't worry, click next. Now at the bottom of this window, you
should see "Repair Windows". Click on it, and there are several options
available here. For this case, which is "Bootmgr is compressed.", CHOOSE
THE LAST OPTION - "Start Command Prompt".
OK type these things (Only works if you have Firefox, can't think of
anything else) below and follow closely:
When Command Prompt is started, type the command below first to ensure
that C Drive or whichever drive which contains all your system files is
selected:
LOOK FIRST!
X:System> (The string on the left is what appears on command prompt,
may differ on other computers.)
Now TYPE "C:" or "D:", depending on the hard disc volume you are
using...
SO IT BECOMES:
X:System>C:
PRESS ENTER
THE RETURNING COMMAND WOULD BE:
C:>
If you get this, very good, continue with the steps below.
Now Type:
CDProgram FilesMozilla Firefox
PRESS ENTER
THE RESULT SHOULD BE SOMETHING LIKE THIS:
C:>CDProgram FilesMozilla Firefox (Press ENTER)
C:Program FilesMozilla Firefox (<<<<< Result)
Now type "firefox".
wait for Firefox to launch now.
it doesn't matter if no internet is available.
Now on firefox, go to File > Open File
Double click "My Computer", and you should see your hard disc there,
but don't double click on the hard disc. Instead, click once on the hard
disc, RIGHT CLICK, and choose properties. AT THE BOTTOM, UNTICK, I
REPEAT, UNTICK THE BOX SAYING "Compress this drive to save space
etc....". NOW CLICK APPLY, WAIT, AND I MEAN WAIT PATIENTLY OK? AFTER
THAT CLICK ON "OK".
AFTER PRESSING OK, DO A QUICK LOOK AT YOUR DRIVE BY DOUBLE-CLICKING IT
NOW. IF ANY FILES/FOLDERS ARE BLUE IN COLOUR INSTEAD OF BLACK,
RIGHT-CLICK IT, CHOOSE PROPERTIES, CLICK ADVANCED BUTTON (Beside
Read-Only Box and Archive Box), UNTICK, I REPEAT, UNTICK the 3RD BOX
Which says "Compress contents to save disc space".
Click OK, Apply and close the folder/file properties.
Now close the box opened by firefox, close firefox, close command
prompt AND AT THE BOTTOM RIGHT OF THE FIRST WINDOW WHICH POPS UP
MENTIONED EARLIER, PRESS RESTART.
for xp:
Boot Manager is compressed
If by accident having compressed the entire boot partition, then Vista will display the following error:
BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
Check points for fixing compressed boot-manager:
* Boot into Windows Recovery Environment (WinRE) and perform a “Startup Repair”.
* If the above doesn’t solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press “Load Drivers” (Instead of “Next”) and use the mini Windows Explorer to right-click the boot-drive and deselect “Compress this Drive” and choose Apply to sub-folders and files.
* If that also fails then boot into WinRE again, and go to the “Command Prompt” and execute these commands:
o compact /U C:ootmgr
o compact /U C: tldr
Mar 30, 2010 | Compaq Presario 700 470024-192 Notebook
Ntldr is compressed
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Aug 30, 2008 | AMD Compaq Presario SR1030NX Athlon...
Acer Aspire 9800 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
