Question about Panasonic CQ-C1303U CD Player
I put in this radio and hooked up a sub with amp in it the cd player works but not through my sub.
    Genius:
  • 1,114 Answers
Check the RCA connections in the back of the unit
Posted on Mar 28, 2011
3 Suggested Answers
elecgooroo
  • 57 Answers
SOURCE: troubleshooting in car cd player
that is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Posted on Jan 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 19, 2009
I have put dual 12 inch subs in my 1999 camaro and I hooked the power wire from the amp to the radicand the subs are working but not to full power. when I go on the radio to turn my subs on it wont let me...
check the remote wire it it needs to be hooked to the atenna power wire on the radio the power wire to the amp needs to go to the BATT. with a fuse make sure your amp is grounded well and less than 18 in. then check your RCA wires after all that then go back and check your sub output on your radio
Sep 20, 2011 | Kenwood KVT-514 Car DVD Player
How do I turn my subs on on my xdm7510 radio
check to see if you have power going to the amp. Battery(+) and Negatve(ground). if those are ok, turn the radio on and check to see if the remote wire(it's usually blue) has power. if you have power on the battery wire and the remote wire from the radio, then there is a problem with your amp. check fuses on the amp if any.
Sep 07, 2009 | Dual Electronics XDM7510 CD Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Sony xplode cd player sub problems
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Troubleshooting in car cd player
Nov 06, 2008 | Sony Xplod CD Player w/MP3 Playback...
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Panasonic CQ-C1303U CD Player Logo
53 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
