Question about Motorola POWER SUPPLY FOR CANOPY (ACPS110) Power Supply
Canopy power supply prob.no light..can it be repaired?my motorola canopy power supply is not functioning,the LED indicator doesnt turn on.can it be fix
Suddenly won't turn on no charge light indicator
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 25, 2012 | ASUS G71G-A2 PC Notebook
Switch on the iron infront of the TV and a large spark and bang came from the right hand bottom corner. POwer went off and the TV doesnt work. Not sure if its repairable or better to purchase another...
Now tv turn on,u still have power and LED power light indication flashes?Yes this tv is repairable the tv power supply board is the causes and problems,that the board where the power a/c cord plug into it,can u take things aparts and putting it back again?Try website like Ebay.com to buy a refurbish power supply board for the replacememt.
Jan 31, 2011 | Hitachi 42PD380TA 42 in. EDTV-Ready Plasma...
When i turn on the tv the led flashes 4 times and tv takes 4 minutes to come on and when it comes on the led flashes 5 times
Flashes of your led light indicates an error code. This is usually caused by leaky filter electrolytic capacitor. This will affect the regulation of the supply and sometimes needs a little warm-up to function normally. This faulty capacitor is in the regulator section/low voltage power supply. The symptom will get worst if not isolated.
This is not DIY. I've advice you to send it to repair shop or look for a qualified technician to fix the problem.
Hope it may help you!
Have a nice day.
JDVillanueva
Jan 31, 2011 | Televison & Video
Tv struck by lightning and will not turn on. Can it be repaired or is it a lost cause?
Yes,it repairable.The tv have power at all like the LED power light indication flashes?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.No power LED light indication all.The power supply board is dead and also the Tuner signal board is dead.Must replaced both boards.
Oct 16, 2010 | Polaroid FLM-3232 Television
Power light flashs off and on and pc clicks
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Well, I was sure that the voltage selection switch was in the right place. And I found it highly unlikely that the processor power cable would suddenly unseat itself. Ugh.
Then I had an idea. I flipped off the surge protector and then flipped it back on. Tada! No more orange lights. Weird. The moral of the story: try the simple stuff first.
I hope this helps and please dont forget to rate my answer. Thank you! :D
Apr 28, 2010 | Dell OptiPlex SX280 PC Desktop
It Will not turn on
maybe ur need a capacitor cuz ur prob over loading ur power supply
Feb 22, 2010 | DHD NTX-2004 Car Audio Amplifier
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Dell optiplex gx260
Reference the Power LED States
Dell OptiPlex and Dimension computers and Dell Precision workstations have incorporated the use of the multi-state power button LED as a hardware status indicator. The power button LED illuminates in two different colors and can also blink, which allows for indication of five different system operation states. (Table 1)
LED State
System State
Steady Yellow The power supply is functioning, but the system is not processing data. This may indicate an issue with the system board or CPU. Blinking Yellow The power supply is receiving power from the source but is unable to properly distribute it to the components. This may indicate a power supply problem. Steady Green This generally indicates that the system is functioning normally. However, if problems are detected with installed components, the system may initiate a beep code. Blinking Green The system is in a Standby ACPI state. Off The system power is off.
Feb 24, 2008 | Dell OptiPlex GX260 PC Desktop
SIGNAL PROBLEM
the radio has had an internal breakdown, possibly a transmitter or receiver failure. The only thing to do would be to replace or repair the unit. How old is it, as it may be under Motorola warranty if its less than a year. If it's not, you could contact Motorola support, and find out if they offer "flat rate" repair.....I know they do this for all of their 2 way radios and pagers, and the cost for repair is usually around 1/4 of new pricing. If you do get in touch with Motorola support, and have the unit's serial number handy, they will be able to tell you if its still under warranty. 1 888-605-2552 is the support number for Motorola canopy. They would be able to tell you if Flat rate repairs are available, and where to send the unit.
Dec 28, 2007 | Motorola Canopy 5.2 GHz Wireless Access...
Computers & Internet Logo
104 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
