Posted on Mar 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer Toshiba B-SX4T Chinese version is not printing.
kong win chang
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert 142 Answers
  • Posted on Dec 09, 2013
kong win chang
Toshiba TEC Expert
Level 2:
New Friend:
Cheetah:
Answers
142
Questions
0
Helped
52855
Points
152
2 Related Answers
Anonymous
  • 24 Answers
  • Posted on Dec 17, 2010
SOURCE: How to configure internal LAN in B-SX4T barcode printer?
I hope thisis understandable.
  1. Switch printer off
  2. Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
  3. Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
  4. Press [PAUSE]
  5. Press [PAUSE]. Display shows IP Address
  6. Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
  7. When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
  8. Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
  9. Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
  10. Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
  11. After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
  12. Step through the above sequences to get the GATEWAY IP ADDRESS you want.
  13. You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
  14. The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
Paul Leather
  • 3 Answers
  • Posted on Nov 20, 2011
SOURCE: Hello, where are a reseller
Resellers and Engineers. MM Barcoding Ltd. Barcode Place, Shaw Street, St. Helens, Merseyside. WA10 1EN. Tel: 01744 778070
I am getting dull print in TEC B-SX4... but i load stock correctly
You may have to realign the print head.
The angle may be different from the original one
What is the best software to use for the Toshiba BSX4T Printer : with LAN card ? jack boychuk
Use seagull dirver and bartender. A light version is delivered with each printer
We have a TEC BSX4T laser printer that is not printing correctly. Once you type info in..press print..the printing becomes progressively off centered with each successive label. Someone suggested the...
Plce the media guide correctly and check that the roll is centered correctly. Else you may have a problem with the alignement of the head on the platen.
2answers
Hello, where are a reseller of toshiba labelprinters type SX4. One of our customers has problems with printing labels. The errormessage on the screen of the labelprinter is: INLINE B-SX4T U5.0 and...
Well at my old company we use to get our's fixed and replaced from toshiba TEC in London.
Campus 300, Spring Way, Maylands Ave Ind Est
Hemel Hempstead, Herts, HP2 7GG
United Kingdom
[email protected].
(0)870 890 7200
I am trying to run a transfer label with ribbon and can't get the ribbon to rewind.
Check in your print options if you are not in direct thermal.
You should be in tthermal transfer
Why does my b-sx4 not print cleanly or in correct area on label?
- Do you have the right Transfer film?
- Check the temp?rature settings
- Check if the print head is not misaligned
Cant center the bar code on the label one out of 5 gets printed properly?
is the paper correctly guided?
Adjust the paper guide and it should work fine
When i print several labels they are not aligned
Check the size of the label and the detection type selected
Ts an sx4t version 5.1 and it comes up with a error message - d042010000390.
this is a syntax error
Normally you should send
{D0420,1000,0390'} for paper size
How do you setup the IP address on a toshiba tec b sx4t printer?
In diag mode (pause and feed key depressed switch on )
go to ip adress and change the value or use the instructions
{IP;2,xxxx,xxxx,xxxx,xxxx'} for the ip
{IP;3,xxxx,xxxx,xxxx,xxxx'} gateway
{IP;4,xxxx,xxxx,xxxx,xxxx'} subnet mask
socket port
{IS;1,09100'} for socket number and activation
{IS;0,09100'} for deactivation
Top Toshiba TEC Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
