Air conditioner install, Goodman 2.5 ton package.
First, which hole is the return and which is the supply. One is 14x14 and the other is 14 x 22.
Second what size breaker and wire do I need to wire it up and does the heat strips need seperate power. what size wire and what size breaker do they need?
Air unit GPC1330H21
Heat strips HKR 10CB
SOURCE:
  • 8404 Answers
SOURCE: Need to how the power
Minim 20 amp circuit ... is this 110 or 220? You need to know.
20 amp circuit needs to have #12 wire. If 110 Volts, you need a black, white and green #12. If 220 Volts you need a black, a red, and a green. If you have anything IN the unit that needs 110 (probably not), you need black, Red, White and Green (bare) #12 wire. Definitely needs to be on a dedicated circuit. If your unit has a resistance heater (electric) you will need a 30 amp circuit (probably 220) which needs #10 wire minimum. 220 volt breakers are double. You will need two spaces in your panel box. Would not hurt to put in heavier wire (#8) protected by a 30 amp breaker ... $ is the governing factor.
Having said all of that --- you should be reminded that I dont even know what country you are in nor your prevailing voltage nor what your national or local codes require. My comments based on installing several Goodman products over several years on the Eastern Seaboard.
Posted on Aug 26, 2011
muttandjeff
  • 359 Answers
SOURCE: wiring a heat strip
DO YOU MEAN FEED IN OR FEEDING HEATING ELEMENT . I ASSUME YOU MEAN TO FEED FROM PANEL THE ANSWER IS YOU MUST RUN 2 CIRCUITS OF 3-cond #6 copper to unit connect the feeds to one breaker and the other circuit to the other breaker the neutrals connect to lug provided or purchase them and frame gnd to case , i would not recommend anything except copper as most mfg do not rec aluminum because on the heating and cooling of the unit and conductors
Posted on Nov 24, 2008
  • 614 Answers
SOURCE: Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Posted on Jun 21, 2009
  • 10 Answers
SOURCE: goodman 2.5 ton 14 seer with txv. low compressor amps
no it's good,man. LOL. The RLA is a max not a target. What is the RLA for the compressor?
Posted on Aug 12, 2009
  • 117 Answers
SOURCE: its 28 degrees out side and my goodman 3.5 ton
Sounds like the heat pump is not running. Check outside to see if the fan is spinning.
Try moving the thermostat to emergency heat and see if that gives you any heat. If it does, then you have heat until you can get a service technician to locate the problem with the heat pump. It could be a wide range if issues from bad thermostat to bad wiring to bad capacitor.
Posted on Jan 08, 2010
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
Blows little heat
Check the filter & indoor coil...could be plugged up.
Dec 13, 2013 | Goodman Manufacturing Goodman GPH1360M41 5...
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
Blower will not blow air with cover on unit when i take cover off air blows through vents on package heatpump
Sounds like return air supply clogged, check filter and duct work also some units have a filter at air handler at bottom some time the installer leaves them in
Jan 03, 2011 | Goodman CLQ36AR49 Air Conditioner
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
How many tons is a Goodman Central Air Unit with Model Number CKL30-IE?
That is a 2.5 ton system. The model numbers are as indicated:
24- 2 ton.
30- 2.5 ton.
36- 3 ton.
42- 3.5 ton.
48- 4 ton.
60- 5 ton.
Hope this answers your question!
Jul 15, 2010 | Goodman CKL60AR60 Air Conditioner
Brand new goodman 2 and half ton package unit runing all the time
Sounds like the Thermostat or board is wired incorrectly(being new)
have the installer come back and rewire it.
Please rate this solution.
Jan 16, 2009 | Goodman CKL49AR49 Air Conditioner
Goodman PCK-060-1C. suction 52, coil/filter/blower/restrictor/drier okay. Recovered the charge and recharged with factory specified amount. The return air 1800 cfm. Motor 3/4 hp. It seems to me the motor...
It seems to me that your suction should be @ 76 or so. 52 is low. the coil will ice up with any suction PSI below 58. Disconnect the unit from the duct work and make sure there is no restriction in the duct size. In other words. Does the unit work properly with out the duct? I find most mobil homes have a restriction in the amount of return. A 5 ton split needs a 20 inch round return. You never see this size return on a package unit. Does the return **** the filter in? I have had to add returns to large mobil homes because there just not designed right.
this is only a possibility. Is the temperature split on the equipment between 18 and 20 If it is then I don't thing you have an equipment problem. Also make sure there are no holes in the duct work.Last one I had unit was working fine but the duct work had a big hole in it from some animal under the trailer.
May 13, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
266 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
