Question about Panasonic ET-LA095 Projector Lamp for PTL795U, PTL595
RESPECTED SIR I HAVE A PANASONIC PROJECTOR PTL595E . THIS PROJECTOR HAVE A FAULT ,THAT HIS LAMP IS NOT ON AND IS POWER INDICATION LIGHT IN BLANKING GREEN AND ORENG . PLEASE FIND THE SOLUTION . THANKS
SOURCE: PT-D3500E Projector
no havent fixed this problem but also unwilling to pay for advice.
this is something that should have supplied by the contractors who installed and fitted
the said products. many thanks for getting back to me but i will now take this up with the project manager.
Posted on Aug 22, 2008
SOURCE: Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Posted on Feb 08, 2009
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
SOURCE: Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Posted on May 03, 2010
SOURCE: the projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Posted on May 13, 2010
As all the posts on here I have the same problem. My panasonic pt-lb10u turns on, green light flashes, fan comes on. Then the green light turns red and the red lamp indicator light comes on. No light emits...
If your projector won't fire up then you can't reset the lamp counter so that is not the problem.
The combination of LEDs you have given does not correspond to an error message. There should be two LEDs, one of which is the Lamp Indicator, and the other is the Temp Indicator.
It's possible that an overheating problem has caused this. Make sure the projector is in an area where the temprature is between 0 °C (32 °F) and 40 °C (104 °F) and the humidity is between 20% and 80% (with no condensation). It shopuld have unobstructed air flow around it.
Disconnect the power. Remove the lamp and place it aside. Clean the air filters, using a hoover, being careful not to damage the filter which is located on the underside at the front of the projector under a flap.
Carefully reinstall the lamp (when you say you replaced the lamp, did you buy a new PANASONIC lamp from a reputable source?) Try to fire up the projector. Note down any combination of LEDs if the projector doesn't work and post hem back here.
Feb 14, 2011 | Panasonic PT-LB10VU Multimedia Projector
Dear sir this product once on green indication within seconds going to red indication.
There are five fans in the projector.
2 for LCD cooling
2 for lamp cooling
1 for power supply and lamp drive unit
if any one is not moving, faulty, broken, than the problem occur.
Experience: many times a broken piece of plastic or self removed screw to stop the fan moving or jam to dust.
Solution: service your projector and fans
Jan 21, 2011 | Panasonic PT-LB51U Projector
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Dear sir, My projector panasonic pt-d5700 projector power indicator blinking red continue & projector not working. achal tewari
    Sounds like a dead lamp, most likely need to unplug for a while to reset and replace the lamp before plugging back in.
    Apr 04, 2010 | Panasonic Televison & Video
    The lamp indicator turns on
    The clicking noise is the protection switch that keep shutting down the unit. This happens when an internal fault had been detected.
    Do the following:
    Unplug the unit from power for some time.
    Remove the bulp and refit it in place.
    Restart the unit.
    If still in protect mode (clicking , lamp light and no start), then there is a fault.
    When the problem is the lamp, the lamp light will come on, but usually protection does not click.
    Before buying a new lamp that is expensive, have the projector checked, testing with particular attention the high voltage board that will supply power to the lamp. That may be the fault.
    If you have a replacement lamp in storage replace the lamp first.
    Jul 20, 2009 | Dell 2200MP Multimedia Projector
    PT-L785U Projector
    if the lamp warning light is flashing, this indicates a defective ballast (lamp power module). if the lamp warning light is lit steadily, then the lamp would be at fault.
    Oct 13, 2008 | Panasonic PT-L785U Multimedia Projector
    Lamp replacement
    Hi there
    There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
    Sep 16, 2008 | Panasonic Videoprojector PT-LM1E...
    Panasonic ET-LA095 Projector Lamp for PTL795U, PTL595 Logo
    46 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
