Question about Kidde i12040 Hardwire Smoke Alarm with Hush Feature and Battery Backup
My smoke/carbon monoxide detector keeps saying "low battery". I have replaced the batteries in all (5) detectors. They are hardwired. The one downstairs goes off continually and now the one upstairs has started saying "low battery"
My Smotec 3786A indicates not to install it in above 85% humidity.
One of my three seems to go off annually or so and this is what
recently put it down to. I was making an espresso coffee on the
stove and it generates a lot of steam and off goes the fire alarm.
I did change the battery to no avail.
Posted on Mar 29, 2011
How do I fix a jammed battery compartment in a kidde i12060 smoke detector?
You could try to pry the door loose with a small screwdriver. To be safe, make sure the primary 110V power is turned off before trying to loosen the compartment door.
This is an inexpensive unit, less than $10, and is easily replaced if you can't get the door open.
If you do decide to replace it, you may want to look into a combination unit which monitors smoke and carbon monoxide if you don't have a carbon monoxide detector already in your home.
Aug 26, 2015 | Kidde i12060 Hardwire w/ Front Load...
My Kidde carbon monoxide alarm keeps beeping every 30 seconds and we have put new batteries in it but it keeps beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
Jan 09, 2012 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
How to fix detector
You don't mention how old the detector is. If it is more than 5 years old the detector may be beeping to indicate the end of its service life. A smoke detector can last much longer but carbon monoxide detectors have a limited life span. If putting in new batteries doesn't fix the problem then most likely you will need to replace it.
May 31, 2010 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
Kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Sep 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
My kidde smoke and carbon monoxide alarm keeps beeping and saying low battery and i don't have a manual how do i open it so i can change the battery?
You will need to remove the unit from the ceiling to reveal the battery compartment on the back. It should just need to be rotated counter clockwise a small amount and will then come loose from the bracket. When installing a new battey be sure to press the battery reminder finger down into the battery compartment or the battery door will not close. Call the Kidde (pronounced kid-a) hotline if you have problems 1.800.880.6788
Aug 05, 2009 | Kidde i12040 Hardwire Smoke Alarm with...
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
Kidde i12040 Hardwire Smoke Alarm with Hush Feature and Battery Backup Logo
894 people viewed this question
Top Kidde Home Experts
Paul Bade
Are you a Kidde Home Expert? Answer questions, earn points and help others
