Question about AMD M863G (M863G15CV22ARV000) Motherboard
No sound from the computer, i need the audio controller driver
  • 961 Answers
I will gve you a couple of things to try first;
1 Find your speaker icon in your taskbar, lower right of screen. Is there a red x on it? Right click on it and a window should come up with your device. It should show a green check on left and power bars on right> right click on the device. A window will pop up and you should see "disable". If you see "enable" click on that and exit. Right click on speaker again and click on "open sound mixer" and adjust your volume.
2 Clcikon "start" find "control panel" and click on to open. In your list(icons), find "device manager". Right click on that, open and click on continue. Click on the box with + next to "sound audio and video controllers". You should see a drop down with your device. right click on it and you should see "disable". If you see "enable" click on that and exit. Right click on it again and click on the "properties" tab You should see "this device is working correctly". Exit that and click on your speaker icon and open your sound mixer to adjust volume.
If this doesn't work please provide me with your computer make and model, Your current Windows version and, a complete manufacturer and model number for *********** board( AMD's board was used by alot of different manufacturers, ie, Pc Chips. Let m know at "add a comment"
Dave
Posted on Mar 28, 2011
How do i get IDT audio sound back
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if you need more help with this poat a reply
hope this helps you
Apr 05, 2012 | HP IDT High Definition Audio CODEC
Every time i click sound and audio devices in the control panel it says application error
you might need to install/reinstall the sound drivers
if your computer came with a motherboard disk the sound drivers could be on it
click start control panel sounds and audio volume advanced speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
hope this helps
Aug 11, 2011 | Computers & Internet
Audio driver dose not working
if you need help with the driver download post a reply
hope this helps
Aug 09, 2011 | Computers & Internet
Theres no audio sound drivers on my sound card
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check:
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer:
Update your embedded sound from Realtek to the latest AC'97 codec.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://www.boxdrivers.com
using this link you will be able select your drivers
hope this helps
Aug 02, 2011 | HP Sound Card
I cannot get any sound from my speakers.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 16, 2011 | Kinyo Audio Zone 2.0 Sound System Computer...
Do you need a driver instaled to use these
yes you need sound drivers
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list
Dec 20, 2010 | Altec Lansing VS2121 Computer Speakers
I can get no sound from my computer atall. device "multimedia audio controller" has no driver, I am unsure which driver I need to install and where I can get it from - my computer is a packard...
hope this helps
Dec 16, 2010 | Packard Bell (030069) Sound Card
Hi, i needed audio sound driver this laptop is tosiba E8/420CME
hope this helps
Dec 12, 2010 | Computers & Internet
They don't work - no sound - do I need to download a driver?
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 16, 2010 | Kinyo Audio Zone 2.0 Sound System Computer...
AMD M863G (M863G15CV22ARV000) Motherboard Logo
77 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
