Question about Lexmark X2500 All-In-One Printer
Where are my ink cartridge located - Lexmark X2500 All-In-One Printer
  • 66 Answers
According to page 13 of the User's Guide, the ink compartment should be visible if you lift up the scanner unit. Once you lift up the scanner unit, there should be an arm on the left side of the scanner that will prop it up , so you don't have to hold it any more.
Here is the link to the Users guide:
http://www.lexmark.com/publications/pdfs/2007/2500/en.html
Posted on Mar 28, 2011
How do I put in ink?
Well Anita, always start with locating the servicing panel that house the ink cartridges, or toner cartridges. Usually it's a panel located at the side or rear of almost every printer and copier on the market today.
Once located, you open the panel and inspect the cartridges, looking for the ones specified by the notification that accompanies an empty ink cartridge. Then find and depress the release switch for that cartridge. The old will slide out and you can insert the new one, but always look out for the removable/disposable protective covering on the face of the cartridge, where the ink is printed from.
Also, there are cartridges on the market now that are refillable at home, and which come in a kit you buy initially at any major office supply retailer.
Jan 27, 2015 | Office Equipment & Supplies
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Print cartridges would not move to center when opening lid so that ink could be replaced
There could be a paper jam in the printer head clearning system. If the head cleaning system is not completing the cleaning motion cycle the carriage will not move the catridge to the centre.
Dec 15, 2014 | HP Photosmart Premium C309A All-In-One...
How do you remove ink cart.
To replace an ink cartridge on a Kodak ESP C310 follow these steps:
1) Make sure your printer is on.
2) Lift the printer access door, and wait for the carriage to move to a position where you can access it. The ink cartridges are located in the printhead.
3) Pinch the tab on the ink cartridge.
4) Lift the ink cartridge out of the printhead.
5) Remove the new ink cartridge from its bag.
IMPORTANT:To prevent the printhead from drying out, insert the ink cartridge into the printhead immediately.
6) Remove the protective cap from the cartridge.
7) Insert the ink cartridge into the printhead.
8) Press down on the ink cartridge tab until you hear a click.
9) Close the printer access door.
That completes changing the ink cartridges.
Thank
Mark
Aug 25, 2014 | Kodak EasyShare Office Equipment &...
My HP Designjet T1100 says "Ink Cartridge Faulty Replace Ink Cartridge". But the cartridge in brand new. Any suggestions?
The most common cause I've seen is that when people put the new cartridge, they forget to remove the seal which makes the ink stay in the cartridge. It is typically a strip that covers the hole where the ink comes out, or else a strip that is located far from the hole, but that needs to get removed or else the ink will not flow from the cartridge
Feb 27, 2013 | HP Designjet T1100ps Printer
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
How to Change ink cartridge on Epson Stylus SX215
#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
Sep 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Where is ink cartridge located on mp 620
Look at the front, the ink cartridge cover is at the bottom right corner. Need to flip open to remove the cartridge
Apr 18, 2010 | Office Equipment & Supplies
Where do i replace the the ink cartridge on a 3700dn printer
Although I can't find the specifics on your model, most HP allow access to the ink cartridges by lifting the front cover. The cartridges then move from their parked location. Note: the printer must be on when you do this. Perhaps you provided the wrong model number, here's a link to HP Support
Dec 07, 2008 | HP Printer Cartridges (Complete List): ,...
Changing cartridges
Did you get the answer for how to replace the ink cartridge, because I don't have a manual myself and I can't even figure out where the ink cartridge is located?
Dec 11, 2007 | Office Equipment & Supplies
Lexmark X2500 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
