Question about Guess Watches
How do you change the day on Guess watch W13083L1? The date and time is correct
pgh_pa_guy
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
escapement
  • 2334 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
  • 26 Answers
SOURCE: Day setting problem
you have to keep adjusthing time froward for 24 hours for the day to change its a pain in the *** but ist the only way
Posted on Jul 13, 2009
mcdevito75
  • 1970 Answers
SOURCE: How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Posted on Jul 21, 2010
  • 3 Answers
SOURCE: configuring time, date etc for my O.T.S watch
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Posted on Jan 07, 2011
The calendar skipped ahead a day and I can't get it back to where it reads the correct date. Can you help?
Pull the stem out to the time set level. Turn the hand around until the date change. Now push the stem back in, pull to date set level and change to current date. Now the watch is at midnight for that current date. Note you can set to current time of day. The Watch will automatically change to correct date for next day at midnight as it should.
Oct 17, 2013 | Michael Kors Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
My analog Guess watch has a date display only (no day). I have re-set the date over and over, but it changes the date at noon instead of at midnight.
Your problem is caused by the fact that the watch is 12 hours out of step.
Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
(if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
Jun 04, 2011 | Guess G85675G WristwWatch
I can't set the day in my guess g13534g
Hi, You just have to release the crown out then keep on moving the crown clockwise untill you get the right date. You only have to set this once then it will keep the correct day for you as expected. Make sure you have the right time and date once you are done.
Feb 14, 2011 | Guess Steel G13534G Watch for Men
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
I have a guess steel watch , and i have set my date and time right , but i cant put the day right , so monday or tuesdag for example.
Advance the watch time 24 hours to change to the next day. keep turning until it reaches the corect day of the week, then reset the correct time and date.
Nov 14, 2010 | Guess Watches
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
Change the day of the week
Most watches have a stem that you pull out to set the time. The little knob on the end of the stem is called a crown. For a day/date watch, there are two clicks. The first click when you pull out the stem is the day / date setting, the second click sets the time.
When you are on the first click, twisting the crown one direction changes the day of the week; twisting the other direction changes the date. If yours has only the date, it could be either direction depending on the manufacturer.
Jun 15, 2009 | Guess Collection Textured Dial Watch
HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Nov 18, 2007 | Skagen 355LSSM Wrist Watch
Watches Logo
29 people viewed this question
Top Guess Watches Experts
Ansel Alberto
Ansel Alberto
Dennis Fitzsimmons
Level 1 Expert
Are you a Guess Watch Expert? Answer questions, earn points and help others
