Question about Dryers
The problem with our Kenmore Dryer model 110C66492500 is identical to Mr. Guy Ducharme's problem with the same model number: There is no heat and the machien will not stop unless I turn the timer off. HELP !! Bob C. Robert Baird
  • 159 Answers
SOURCE: roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Posted on Aug 22, 2007
  • 94 Answers
SOURCE: Kenmore Dryer Model 11063102101
Probably the timer is defective and needs replacing.
Posted on Oct 07, 2007
SOURCE: kenmore heavy duty clothes dryer will not heat
most problems with dryers not heating is the thermo fuse is blown. bout 20 buck to replace it looks like a small white flat football. but most likely if it went out that means the the high temp thermostat is messed up too
Posted on Feb 07, 2008
mikedurland
  • 481 Answers
SOURCE: Kenmore (Whirlpool) Dryer Model 110.64632300
make sure you are getting a full 220v at the outlet. these symptoms are sometimes caused by one side of a dual circuit breaker in the house tripping leaving you with a partially functioning machine that seems to have power. d8d2a06.jpg
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 08, 2008
  • 958 Answers
SOURCE: Dryer not heating
normally, it is the thermal cutoff switch. test this part for continuity and if there is non, then that is your problem.
tnx 4 using fixya,
drcool
Posted on Sep 29, 2008
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Kenmore Elite gas dryer, ''NO HEAT''.
fuse is located behind rear panel of machine white w/2 blue wires coming to it
Apr 14, 2010 | Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
DRYER HEATING ELEMENT
Kenmore dryers are manufactured by Whirlpool. In many cases the part numbers are identical between model numbers. Look at the dimensions of the heating element and compare part numbers. Chances are, the parts are identical.
Jun 29, 2009 | Dryers
Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
Kenmore dryer model #86870100 runs but no heat
this kit mounts on the heater element chamber. The small one will be open. The big one failed also because it is rated to shut down @250°F. The little guy is rated at 300°F. NOTE: when this limit fails it is a sure sign of a blockage of lint somewhere.8e8a912.jpg
Dec 15, 2008 | Kenmore 63942 Dryer
Runs but no heat
most common cause of no heat is a blown thermal cutout, over temperature cuthout, thermal fuse (any of a dozen or more names for the same article
examine the exhaust vent ducting inside the dryer for screw on device that looks like this d7573a1.jpg or this 0874a9a.jpg, with wires on the terminals. they are not resettable but they are cheap. despite the large number of dryer models there are only a few cutouts, used in multiple dryers, the local parts guy will be able to match it easily.
test with battery annd bulb, or ohmmeter
conducts-good, no conduct- replace
if you havent disposed of them already, retain the heater and thermostat, they are probably good, and will make spares if the parts guy wont buy back the replacements
Aug 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
