Question about Canon Office Equipment & Supplies
My Canon MF4100 Series printer / scanner is not printing any documents. Plus the LED display light on the front of the printer is showing both the green and red lights. Units switches on when using the main power on / off switch however when i try to switch it on at the on / off button situated on top of the printer nothing happens. What could be the Fault? Is there anyway that i can reset the printer to the original settings?
AlmostBob
  • 550 Answers
SOURCE: Orange LED blinks 5 times then a 2 second green
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
If you type in 'flashing power light' in the problem box, for 5 you get print head failure, often it means the connectors between cartridge and print carriage are dirty, can be cleaned with a pencil eraser and a soft cloth. there is a sequence of checks and repairs to follow on the canon service page
Posted on Sep 02, 2008
IrishDruid
  • 2712 Answers
SOURCE: Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Posted on Oct 23, 2008
gwbm
  • 353 Answers
SOURCE: epson stylus c42 plus
If both red and green lights are blinking, it usually means that your waste ink pads need replacing. This requires dismantling of the printer and resetting of the protection counter. If you feel up to it, respond with your e-mail address and I will send you instructions - but it's not easy.
Posted on Jan 31, 2009
  • 10 Answers
SOURCE: Canon MF4100 Series UFRII LT print problem
sounds like an error with the printers ink cartridge reader
Posted on Jun 18, 2009
  • 313 Answers
SOURCE: After disconnecting and reconnecting my HP 1280
close the rear door (duplexer) tightly
Posted on Mar 17, 2010
Many times my printer shows communicaion error
The first thing I suggest you try is simply opening Print & Fax, selecting and pressing the minus button under the printer list. This will remove the print queue but not the driver so you will just need to add the networked printer again. With Print & Fax still open click the plus button to add. With the Default view selected the Scanner will appear first. And if you wait a few more seconds the Printer will also be displayed. Select this entry, which will be shown as canonijnetwork in the Kind column. The Print Using menu should change to Canon series and when it does click Add to complete. Now try printing with this new queue. If this doesn't work then reply and we'll try something else.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Apr 19, 2014 | Canon Office Equipment & Supplies
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Overheats when printing pictures on transfer paper and now it will not print anything.
hi
i have problem with my brother prinetr MFC-8460N
IT SHOWS DOCUMENT JAM
ALSO MESSAGE ON SCREN
CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY
STATUS SHOWS RED LIGHT
WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY
RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME
PLEASE ADVISE
Nov 10, 2009 | IBM Infoprint Color 1357 Led Printer
Jun 18, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF4100 Series UFRII LT has paper jam after i accidentally turned off the printer while it was int he middle of printing. The LED screen on the printer says "Paper Jam" then "Lift panel to open open...
just press the resume button and if the problem presist switch off your printer and computer and again restart both of them. and if still paper jam then press resume button.
Feb 27, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
No printing on Mac OS 10.5.1
Check under the Apple site for this issue. I use Leopard and can copy and print with this machine. I have not tried the fax, however, I assume  it will work. The scanner does NOT work with Apple...at least yet...I am not sure if it is Apple or Canon or both who are at issue for this. As per the post below, the duplex works just fine for me. You may want to consider the possibility of removing the current drivers and reload the one's currently posted by Canon.
Duplex Printing
Apr. 19, 2007
Archon Fung
I figured out how to make duplex printing on the MF4150 work! Canon Tech support says that duplex printing is not supported, but they are mistaken.
Here is what you need to do:
1. go to the Canon site and download the latest UFRII driver (v1.5) and install it
2. in the application, go to page setup and select "Format For:" MF4100 Series [this was what I did not realize]
3. then, when you go to print, select the finishing tab, and then select 2-sided printing.
If you skip step 2, and you application defaults to "format for any printer," the 2-sided option will be greyed out. Other printer drivers do not require this, but the Canon driver does.
Nov 26, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
Cant print from workstations
Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
89 people viewed this question
old marine
old marine
