Question about Philips 50PFP5332D 50 in. Plasma Television
Tv started clicking over and over and is not turned on.I unplugged it and it still clicks when I plug it back in. It wont start.Is this under warranty?
TRY HEATING THE BACK WITH A BLOW DRYER IT WILL TURN ON.JUST MAKE SURE IT IS UNPLUGGED FIRST.
Posted on Apr 12, 2011
TV won't turn on, only clicks. Unplug and plug back in TV comes on.
Had same problem but it was under warranty it was control board going out. It started like yours then eventually Icouldnt change anything on tv even with buttons on tv or remote
Jul 09, 2014 | Toshiba 46SL417U LCD TV
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
Wont turn on clicks then clicks back off red light blink 7 times
check the capacitors and replace the power components check mother board also .. not handy with electronics and soldering call tv repairman 75-150 dollars Fix ?????
Sep 21, 2012 | Panasonic TC-50PX24 50 in. Plasma TV
My computer keeps on saying that a usb device not recognized. i havent connected any device to my computer. how can i fix it? tnx a lot..
First simply try turning off your computer then unplug your computer from the "power supply".
Wait 15 - 30 minutes and then plug it back in and restart. If that doesn't work....
1. Click Start, Control Panel, and then Performance and Maintenance.
2. Double-click the System icon.
3. Click the Hardware tab and then Device Manager.
4. Double-click Universal Serial Bus Controllers.
Uninstall the USB ports from here. To do so, right-click the USB controllers that are listed under Universal Serial Bus Controllers and click uninstall.
Hope this helps
Nov 27, 2010 | Sony Televison & Video
Akai TV wont turn on right
this could be the power supply board
May 13, 2010 | Akai LCT2715 27 in. LCD Television
Clicking power supply? wont turn on
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 02, 2009 | Philips 32PF9964 32 in. Television
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
Philips 50PFP5332D 50 in. Plasma Television Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
