Question about Hitachi P42H401 42 in. Plasma HDTV
My Hitachi Plasma 42" wont
  • Hitachi Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck..
Posted on Mar 28, 2011
Tv turns on but stays on standby
Have you checked the manual? Here is a link http://www.manualslib.com/manual/419601/Hitachi-42hds69-42-Plasma-Tv.html
May 15, 2016 | Hitachi 42HDS69 42 in. Plasma Television
Volume works but picture wont show
It is likely your TV has power supply trouble.
Nov 08, 2013 | Hitachi P42H401 42 in. Plasma HDTV
Hello, My Hitachi 42" plasma is about 5 years
A description of the fault may help with an answer.
Sep 18, 2017 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
My Hitachi tv model p42h401a will not turn on. The "standby"light is not on either. I have checked the power supply and that is working.
Have you opened the actual TV and checked the power supply board inside? Because that is what it is. You need a new one.
May 09, 2011 | Hitachi 42HDT79 42 in. Plasma Television
Intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
I DIDNT GET ANY HELP FROM YOU GUYS, TAKE YOUR "FREE" TECH SUPPORT AND SHOVE IT UP YOUR ***!!!!!!!
Nov 12, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi plamas tv wont turn on just flashig blue on light
Power Supply Failure is the most common on a Hitachi.
For further answers please provide the Model Number.
Sep 06, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Tv wont turn on
If your AVC works and would like to sell I will buy this unit
Jun 03, 2009 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
My plasma screen wont turn on
THERE IS TOO MUCH TO EXPLAIN ON HOW THE PANEL IS TURNED ON AND THE VARIOUS CAUSES. TAKE IT TO AN AUTHORIZED SERVICER.
Apr 03, 2009 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Hitachi 42plasm tv
take it back to the store, make sure the power cod is in all the way and you dont have it on a switched outlet, see if you can see any cracks or if the box was damaged/
Dec 08, 2007 | Hitachi P42H401 42 in. Plasma HDTV
Hitachi P42H401 42 in. Plasma HDTV Logo
603 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
