Question about Samsung SCX-5530FN Laser Printer
Samsung scx 5530 door open error two micro switches seem to be good
let me help
  • 196 Answers
SOURCE: ON Samsung SCX 4216 Error: Paper
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow" by compressed air.
more over roll the toner gear check if its not obstructing to something .
secondly try to cut/delete any pending print jobs thats right next to clock on your dektop.then restart PC and then plug the printer and PC on see if it works.
If still problem exist then, post your query here ,
I hope this solution will helpful for you
Anymore help regarding the issue, I am here to help
Thanks
Posted on Apr 05, 2011
SOURCE: Samsung SCX-4x16 printer error
getting an error while printing from a particular application. Error Printer could not print any more because the port is in use. Printer is Samsung Samsung SCX-4x16 ver 5.56. please help!!
Posted on Jun 24, 2008
  • 113 Answers
SOURCE: OPEN HEAT ERROR
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Posted on Mar 02, 2009
Evildice
  • 222 Answers
SOURCE: My samsung scx 4100 series printer showing open
this is a fuser problem. Maybe lamp is broken or heat sensor didnt work properly.
You can fix it whit repalcing fuser module or replacing broken parts (cheaper way).
Just visit authorized service - my advice!
Posted on May 27, 2010
SOURCE: Printer Samsung sCX-4521f CRU Fuse Error
Posted on May 29, 2010
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Front or vrear cover open
there are 2 switches regarding this error message " front and rear cover open." so pls. check with the front door right side portion. you can see a small leaver there, pls. check that liver correctly go inside the cover after we close the front door.
other switch at the back door paper exit area. pls. check the door closed properly nor not ? that door control a switch liver attached with the fuser unit.
first switch in the HVPS board and second switch at SMPS.
kindly check it and revert back.
May 05, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Samsung Printer SCX 4300 message "Open Heat Error"
on printer, in menu there is clear setting, find it and do ""clear setting" , "all setting", then will be fine
May 29, 2011 | Samsung SCX-4300 Monochrome Laser...
I have a new replacement fuser unit for my Samsung SCX 5530 FN MFP. How do I remove the old one and instal the new unit
Easy. Open rear Cover and remove 4 screw that holds fuser. Take out old and put in new and back the srews and that's all.
Feb 09, 2011 | Office Equipment & Supplies
DOOR OPEN ERROR MESSAGE SHOWING ON SAMSUNG SCX-4725FN PRINTER BUT THE DOOR IS CLOSED
Hi there remove the cartridge and clean the internal part. Then insert the ink cartridge and try. If you face same problem then reset the Printer and turn off for 5 minutes. Now again turn on and let me know the result.
Jan 21, 2011 | Samsung SCX-4725FN All-In-One Laser...
Scanner locked Samsung scx 5330FN How do I unlock
I'm not sure about the 5530, but the 3160 goes like this (and I think that it is similar). Lift the top, look at the glass, left to the glass there is a lever and "unlock" position.
Dec 02, 2010 | Samsung SCX-5530FN All-In-One Laser...
My samsung scx 4100 series printer showing open heat error.....what can i do for this error
May 25, 2010 | Samsung SCX-4100 All-In-One Laser Printer
Samsung scx 4200 laser printer diplay says open heat error"
Good Day Sir,
Your machine display "open heat error" it means there is a problem in the fuser unit. I suggest unplug the power cord and plug it back again. If the problem persists you must call for service.
thank you.
Apr 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
OPEN HEAT ERROR
Good Luck!!!
neo
Mar 02, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Printer displays 'No paper - Add paper'
That is if the lens present in your printer ( above the paper Tray) must have filled with dust. just clean the lens and try it out.
Aug 11, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-5530FN Laser Printer Logo
777 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
