Air does not come through the vents on the dashboard when vent is selected, although the fan motor is running.Vents are not opening. What controls the open and closing og the dashboard vents?
    Problem Solver:
  • 7 Answers
You posted this in the computer section... However, and you do not provide info on your car/truck...
Most cars utilize vacuum to control the baffles that directs the air flow... when the vacuum is lost etc.. the default is to blow via the defrost vents... this may be the issue.,
Posted on Mar 29, 2011
Air will not come out of a/c vents
Your controls are vacuum operated. Make sure that there is vacuum present...if not find the disconnect. Or, the vacuum "motor" that controls air direction has failed or is stuck.
Jun 18, 2009 | 2001 Jeep Cherokee
My 96 dodge ram 4x4 has a vacuum leak somewhere the air blows from the vents until i accelorate then it shifts to the winshield defroster vents once i let off the gas it switches back to the vents at...
there are two small black vacuum lines near the A/C accumulator. These Tee into a single line that goes to the intake plenum. If you install a vacuum check valve in the one that comes from the intake it will solve your problems. Just did it and fixed mine that was doing the exact same thing......Good Luck
Aug 07, 2010 | Dodge Ram 1500 Cars & Trucks
Air stops blowing through the vents when accelerating
u have a loss of vacuum to the ac mode control switch, this switch applies vacuum to diff vacuum motors to move air to diff outlets, dash, floor, defrost etc. either the vacuum line or vacuum resivior at the engine is leaking or the mode control is leaking vacuum.
Aug 14, 2009 | 2003 Lincoln Navigator
No air coming from dashboard vents
Check the vent settings on the air control unit. If it is still not working then refer to a mechanic to have the air unit looked at for elecrical problems and to make sure all the air vents inside the ducts are opening and closing properly or that there is not a short in the wires to them or the motors are bad
Aug 03, 2009 | 2003 GMC Yukon Denali
Blower runs but no air out the vents
You may have some debris blocking the passage of the vents. You may want to open the dashboard to investigate further. The blower motor may be running but it may not be driving the actual fan.
Jul 07, 2009 | 2001 Jeep Grand Cherokee
NO AIR BLOWS FROM VENTS
i have the same problem on my 84 grand prix..ther is black wire that heat runs through i broke my cause it was so old an dry rotted an the heat stoped coming out the vents but comes through the dash by the winshield
May 14, 2009 | 1984 Pontiac Grand Prix
No air/heat from Vents in 89 delta 88
1996 olds lss .no heat from vents which seem blocked.The fan runs
Dec 19, 2008 | 1989 Oldsmobile Delta 88
Main dashboard air vents
there is an air flow motor that changes the vents and opens and closes them. unfortunitely you truly want to wish this not to be your issue because in order to change it the entire dash AND heater box must be removed from the vehicle as well as the a/c discharged.
Jul 11, 2008 | 1996 Audi A4
Air Vents
Check the vaccume line going into the firewall. Mine dry rotted and I had the same problem. I replaced the line and now it works fine.
Jun 14, 2008 | 1997 Jeep Grand Cherokee
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
