Question about Dynex Wireless-G Broadband Router
How do Ichange my network security key on my dynex router
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Where can I find the
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
Posted on Feb 01, 2011
How do I get the security key for my dynex dx-wegrtr without the manual
Log into the routers interface usually 192.168.1.1 or check the default gateway address with the ipconfig command in the command prompt. Then navigate to the wireless security tab and the key should be listed.
Mar 05, 2011 | Dynex DXWEGRTR Router
I astray the serial of my plowing how do I get the serial diner that no I can go with my lapto to the network Wireless is the numbering of the detachment posterior part of him plowing my Dynex agredeseria...
If i am able to understand your problem, you have lost the network key ( or the password you have set to your router for security purpose )
If this is the issue, i will be able to help you find the key for your network ( it is called WEP or WPA or WPA2 key )
Follow the instructions below and you will be able to fix the issue. Click on the link given below.
Link
Nov 02, 2010 | Dynex Wireless-G Broadband Router
Do not have cd to set up model no.dx-e402
You can set it up with the manual:
http://www.dynexproducts.com/t-product_documentation.aspx
Mar 27, 2010 | Dynex 4-Port Ethernet Broadband Router...
I need to get the security pin number for Dynex Router. I have moved and can not fine the package I had the software in.
Are you trying to connect to the wireless network on a VISTA computer ?
sometimes it will ask you for the PIN number on a vista computer . In that case on the same window, at the bottom, you will find the option , I want to enter the key or I want to connect to the network. Click on that option .
After that it will ask you for the wireless password , if your network is secured.
If you are looking PIN for other purpose then the PIN number might be on the back side of the router also. It is 8 digit number.
Click Here for more info about networking
Nov 13, 2009 | Dynex DX-E401 Router
Trying to connect my dynex router to ps3 keeps asking for ip adress can u help
PS3 might not be getting the IP address from the router /
Is your wireless network secured network ?
Make sure that you are typing the correct network key .
check the wireless settings of router.
Click Here for step by step solution
Oct 31, 2009 | Computers & Internet
How do I find the WEP Code for my Wireless G Dynex?
The wep key is setup on the wireless router, not the adapter. If you do not have the login information for the router, then the easiest thing to do is reset the router to default settings (this removes any existing keys) and then configure it with a new key. If you reset the router, you will need to connect to the router with a network cable to reconfigure it.
Oct 07, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Unable to connect new laptop to network without Dynex security key/passphrase. Screen box asks for security key. I don't have this or know where to get it.
If there's computer strongly connected (by network wire) to your router, go to the following site: http://192.168.2.1, leave the password empty, from there when you get inside you may see the key (try looking for any menu contains the word wireless)
May 19, 2009 | Computers & Internet
Dynex network security key
  • Launch Internet explorer from a computer that is wired to your Dynex router. On the address field type 192.168.2.1, press Enter.
  • It may asks for password, if you have created a password to get into your router's page type it in. Otherwise, just leave it blank.
  • Once you're in the User Interface of your router, click Wireless sectionfrom the menu. Then click on Security.
  • There you will find the wireless security key or network key enabled in your router.
Hope this helps!
Nov 22, 2008 | Computers & Internet
Router Password
That is the wireless security key or network key configured in the wireless settings of the router. Can you tell me the exact model number of the router you have?
Nov 15, 2008 | Dynex DX-E401 Router
Siemens router & Dynex adapter
Double check if there is any wireless security enabled in your router. Verify if the type of security enabled in your router is already supported by your wireless adapter. If the wireless security enabled in your router is not supported by your adapter, change the security to something that will work with your adapter.
Try connecting your computer with dynex Wireless G USB to different wireless network for further isolation.
Oct 02, 2008 | Dynex Computers & Internet
Dynex Wireless-G Broadband Router Logo
54 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
