Question about Porter Cable C2002 150 Psi 6 Gal Compressor
Pump wont start on auto - Porter Cable C2002 150 Psi 6 Gal Compressor
I replaced fuel pump. the car ran for a short while,then stoped. Now it wont start.The fuel pump wont make any sound.what do I do?
Truck suddenly stops running, acting like it's out of fuel ...
www.cargurus.com > Questions > GMC > Sierra 1500
CarGurusJul 11, 2013 - There is fuel in the gas tank and, I can hear the fuel pump when I ...start it and let it run until it dies then check the pressure and shut the ... 1999 chevy tahoe and I have replaced the fuel pump and fuel filter. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
How do I know if it's my fuel pump or the fuel filter - CarGurus
www.cargurus.com > Questions > Toyota > Camry
CarGurusAug 8, 2007 - My son (14yrs old) was sitting in the car with it running while i ran into the store. ... when you stop and start idling it will die because the pump stopped and ...i need to replace my filter or should i put it back on and try to start the truck? ... If yourfuel pump pressure and volume is within spec's then you need to ...
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Dec 29, 2015 | Cars & Trucks
Car wont start at times
When this happens check the fuel pressure, this is typical of a failing fuel pump. The pump is located in the fuel tank. A quick way to check this is to buy a can of spray starting fluid (buy it at a auto parts store), when it fails to start spray the fluid into the air intake of the engine, if it starts right up the pump is likely the problem. I assume that the engine cranks over and just will not fire up. If it no that then let me know and I can give you other possible causes.
Jul 22, 2017 | Acura Integra Cars & Trucks
Why wont my truck start without starting fluid?
Could be the Glow plug control module or glow plus them selfs....
Aug 22, 2011 | 1997 Chevrolet Tahoe
Chrysler 300m wont start changed fuel pump. Was acting like it wanted to start before i changed the fuel pump, with starting fluid. the car acts like its going to start but wont. The relays have been...
What prompted you to change the fuel pump to begin with? Did you check the codes on the dash? Or have someone OBD check it? It could be a crank sensor, but the codes should reveal that. Codes first and work backwards, please.
May 27, 2011 | 1999 Chrysler 300M
Changed fuel pump pump on a 93 grand voyoger se will start but wont keep running when press gas pedal
two possibilities are the throttle position sensor is bad/disconnected or the fuel pump is not hooked up properly i.e. the o-ring for the pump is not sealing at the tank. Check your fuel pressure at the rail on top of the engine with a gauge set you can borrow for free at Advance Auto, Pep Boys, Auto Zone or other commercial auto supply stores.
Mar 26, 2011 | 1993 Plymouth Voyager
95 wrangler wont start
Please refer to this solution: http://www.fixya.com/cars/t1016149-1989_jeep_cherokee
It's probably the A/C relay under the hood indeed. And your battery might have gone bad too.
Aug 23, 2009 | 1992 Jeep Wrangler
Engine cut out after running o.k for 1/2hour hard to start
I would start with the Fuel Pump Relay. Check the Fuel Pump, Fuel Filter and Belt Tension.
Jan 25, 2009 | 1999 Daewoo Lanos
My 99 Suburban is intermittently starting.....
Unfortunately the fuel pump can still be bad. The pump has a check valve on it that wears out. The pump will continue to run but, struggles to supply enough fuel to start the engine. You can buy a fuel pressure test gauge from Auto Zone or that type of auto parts store and check the pressure. You can purchase a fuel pump from them too.
Dec 27, 2008 | 1999 GMC Suburban
99 chevy suburban intermittenly not starting....fuel pump is runn
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
134 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
