I want to buy machine like printers laptop computer, to be browsing freely in my home, charting with my friend and groups like u, now since i cant afford it as a student, what do i do?
  • 66 Answers
If you need certain computer equipment (such as a printer, laptop, desktop computer) but don't care too much about extra features, I suggest looking at the lowest price available for whatever hardware you need. The cheapest costing stuff usually is functional at what it does, and doesn't usually have more features than what it's supposed to do. ( For example, the cheapest printer may not have fax built in, but it will print.)
The next thing you could do, is check craigslist.com and look in the free section of your area. Some times, people give away old hardware they no longer need.
Posted on Mar 28, 2011
How do i setup scanner from my machine to my laptop? please start from step 1 including cable connectios and scan to folder instructions. I am using windows 8.1 pro
Before you even start, your machines "Network Support" firmware needs to be up to date to be able to connect to a Windows 8.1 PC.
Secondly your machine has to be networked. No USB scanning supported on Ricoh Devices. Create a shared folder on your C: drive called "scans". Share so "everyone" can access the folder. On the MP2852 select scanner mode and tap the block with "Prg Dest" on the screen. Select Folder and Browse for your PC. Enter your PC Username and Password when asked. Find your shared "scans" folder, select it and then tap OK on the screen. Next enter your name and save. You should be good to go. Keep in mind anti-virus and firewalls can block it. Also ensure your PC is part of a "Home Group" otherwise you will not find your PC when you browse from the MP2852. If your PC is not in a "Home Group" then you can just create a "Home Group" under your "Network and Sharing Center" and while you are there ensure that "Password Protected Sharing" is switched off under your "Advanced Sharing Settings" also found in your "Network and Sharing Center".
May 28, 2016 | Ricoh Aficio Mp 2852 B&w Copier
Tip
How to connect USB Printer to the Home Network or Sharing a Printer to multiple...
Connecting the USB Printer to network
1) Right click on My computer (
2) Click on Properties
3) Click on Computer Name
4) Click on Change (where it says "To rename this computer or Join a domain, Click Change")
5) Give Name to your Work Group
"Type the some Name in the BOX"
6) Click OK and Restart the Computer
** NOW THIS COMPUTER IS A PART OF WORK GROUP **
(settings on Main Computer where the Printer is installed)
7) Now we can share whatever you wana share
8) Open control Panel
9) Open Printer and Faxes right
10) Right click on the Printer Icon and click on Properties
11) Click on Sharing
12) Click on share this printer and *Name the Printer if you want share
13) Click on Apply now this Printer is in Network
Network the Second Computer
13) Go to each computer
1) Click on Start - control pannel -
2) Click on Printers and Faxes
3) Click on Add a Printer
4) It will show Welcomr to Add Printer Wizard
5) Click on Next
6) Select "A network printer, or a printer attached to another computer
7) Select browse for a Printer and HIT NEXT
8) It will show you the WORK GROUP and when you hit on it it will show you the Printer
9) Click on Next and OK
Its Done the Printer is Shared and you can take a print out.
Note : The Main Computer should On in order to take Print-out
Hope this will help you connecting your USB printer to the Home Network
on Jan 21, 2010 | Office Equipment & Supplies
Can I join a Toshiba 281c to a home group network?
It can be worked with a desktop pc having windows 7 straightly configured to 281c and if the device is shared. Then u can access the desktop pc and browse 281c and send prints. Better to start with as a simple peer to peer connection use TCP/IP and observe that it can be accessed via Internet browser, If the copier utility page appear alright that means ur connected. Good Luck!!
Feb 22, 2015 | Toshiba E-studio 281c Copier
I cant hook my Lexmark X3550 to a wireless network. How do I do this?
You will need a print server to do this. Many stand-alone USB print servers do not support the bi-directional communication needed for the scanner of an all-in-one. (Check the specs if you are using one of these.)
A better option would be to connect the printer via USB to one computer and then share it across the network. A Windows 7 Home Group for example would be a simple way to set the feature. You may need to set the firewall to Trust the other machines in the network.
Set up the printer on the first computer as you normally would. Get the software from http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-X3550/catId=cat10004-category&prodId=3924-product;jsessionid=51301F9D038596164B244112F2F14143.node4 if needed; click on Download Drivers. Then install the software on the first computer and then connect the USB cable. Set the printer to be shared (Start > Devices and Printers and right click on the printer. Find Printer Properties and the Sharing Tab.)
Make sure that the Home Group is set up and all the computers have joined the Home Group if using that feature. For other Windows computers on the network, get the software and then add the printer as a network printer from the Devices and Printers Add a Printer Wizard. If the printer doesn't show up, check the firewall and sharing.
I hope this helps.
(I have never connected an all-in-one over a Home Group. I do not know if the scanner works in that case.)
Nov 11, 2010 | Office Equipment & Supplies
Hi ..i have a asusA6500R laptop.i would like to reformat it but i cant find my product key..please help me..
In order of preference:
1) Borrow a legit friends CD and install using that
2) Buy one off eBay and install using that.
3) Download from usenet after reading reviews of it and install using that
4) Download from bittorrent and install using that.
Those are listed in order of risk the disk might be infected with a root kit, but I wouldn't worry too much, the chances are quite low it is.
As Microsoft are fond of saying, you buy the licence. You have a legitimate licence, the key is probably stuck to the bottom of your laptop. Download the same version and you have committed no crime.
You could also ask someone at a friendly local computer user group if you may borrow their CD of the same product. It's not like you have to go there twice ;)
Aug 06, 2010 | Computers & Internet
I have problem of local printer is connected to domain i cant shared this usb printer on other connceted same domain pcs Basically i have one usb printer and have 20 pcs all are in domain so i want to...
Well you install the printer on the PC required, then in the setup SHARE the printer. You must then install a printer in each one of the "Clients" when asked what sort, use NETWORKED printer and navigate to where ya Printer is on the network using the "Browse" and choose it, then ya good to go.
I have found a more detailed link for your Convience http://uis.georgetown.edu/software/documentation/winxp/winxp.network.printer.html
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Instaling network printer from main computer
On the Vista computer, right click on printer, go to sharing tab, click on Additional Drivers button. On the next screen you need to select Windows XP.
This will ensure that whenever a print request is queued from any computer that runs on Windows XP, it will process the request on the Vista machine.
You should also try to ping the printer. You should also check if the computer is able to share files with Vista machine.
Apr 02, 2009 | Microsoft Windows XP Professional SP2 for...
Proxy browsing
If you are on a domain, you can use a group policy to set and lock this box from becoming unchecked, and if they are a laptop user you can set it to if they are in a ceratin OU you can only allow laptop user to uncheck this box, so when they take it home tey can browse the internet.
Hope this helps, If so please rate accordingly. Thanks, David
Mar 19, 2009 | Cisco 1700 Series Router
27 people viewed this question
k24674
jasbo
jasbo
