Question about Canon imageRUNNER 400S Copier
I have copier ir 400s sir i am getting error when i started the machine the error is E014 thank you
  • Canon Expert
  • 270 Answers
This is an indication that the fuser ( hot rollers on left side of copier ) are not turning. This could be caused by several things. Try turning the green knob behind front door. Does it move smoothly? If it doesn't then remove the left side fuser door and remove the fuser assembly. The bearings for the upper and lower rollers could be bad. If the fuser moves easily, then it could be a white gear that is located on the upper right of the fuser assembly. This is the drive gear for the fuser. The gear tends to wear out over time and has to be replaced. This should get you in the right direction to solve the problem.
Posted on Apr 14, 2011
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
The error code means that the hard drive has crashed or is failing. To resolve the problem you will need to replace the hard drive and have it flashed before you get it. Or call the place you got the copier from and have them send you another hard drive or return the copier back to them... Good Luck
Jun 06, 2013 | Canon imageRUNNER 400S Copier
Machine canon ir 400s error E051
hi sir my xerox machine IR 400 the error code e220
May 12, 2012 | Canon imageRUNNER 400S Copier
CANON GP405 ERROR E014 PROBLEM
sir i have ir 400 photocopir machin than problem is e803,e805 than coad plese give me soulison...............
Jan 06, 2012 | Canon imageRUNNER 400S Copier
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me....
Jan 06, 2011 | Canon imageRUNNER 400S Copier
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
E805,E803,E002 Error Problem
hi sir my xerox machine ir 400 the error code e0110 so now please help me
Sep 24, 2010 | Canon imageRUNNER 400S Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
No print, e805 and e014
The E 805 refers to a locked up fan motor, and the e014 is for the fuser (the part that get hot) not turning correctly. both of these problems require a technician to fix.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
I am having Cannon IR 400 .please help me in solving the problem of error E014 & some times is soing E 051,E 901,
Hello sir ; All the code you display are motor problem ,check the fuser unit motor first and then go to main motor, most likel is maint motor have problem, if that true replace it ,that is only way you can do.
Jun 13, 2009 | Canon imageRUNNER 400S Copier
when I start my machine the error code e014 appears and machine do not run.
Dec 24, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
47 people viewed this question
old marine
old marine
