My AIWA CX-Z720 doesn't seem to know it has CDs in its rotary changer and keeps skipping until it gives up the search!
  • Anonymous Jan 21, 2009
    Hy. I'm French and have the same problem on my Aiwa CX-Z720. Even if I have 3 CDs in it, it doesn't find them.
welcomejee
  • 10594 Answers
SOURCE: aiwa cd3 model #cx-na 22u
Optical lens might have dust on it so...Try to clean optical lens with cleaner CD then check.
If problem still exist then clean lens with cotton bud by taking off top cover of unit. Make sure to unplug unit from AC outlet before opening top cover.
Posted on Jan 09, 2009
SOURCE: How to play CD on Aiwa NSX-3500 (part of CX-N3500U) w/o remote control?
I thought that I had the same problem. I then discovered that when I put 3 CD's in it started up on it's own. If you push the demo button you can see how it's supposed to light up the number of tracks in a square on the right of the display. It wasn't doing that until I put in all 3. Then it started up and I was able to use the disc 1, 2 & 3 buttons to change from 1 CD to the next and I used the Up and Down buttons to change songs and the play button above the tape deck is multi-functional. Hope this helps.
Posted on Apr 27, 2009
  • 58 Answers
SOURCE: 2001 Lincoln LS: CD Changer wont eject CD's. Keeps
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Posted on Sep 17, 2009
taran_2005
  • 10515 Answers
SOURCE: Aiwa 3-cd changer # CX-NAJ20U
Is this an issue with a particular brand or random?
If it is random, this is an internal problem with player. As the CD's come out of player with scratch, it could be a problem with drive or lens problem. You are correct in thinking that repair would not help as the cost of repair is quite high as compared to the cost of the product.However, you have to understand that this is a consumer market, and all manufacturer's ( most of them excluding Bose ) made their product in such a way that once there is an internal problem, the best option would be replacement.
You could try to fix it, however you have only limited options unless you wanted to open and fix it yourself.
1. Unplug the unit for few minutes, say 15 minutes and then turn it ON. This would reset the machine. Then, give it one more shot with a new CD ( make sure that it should not be scratched ).
2. You could use a lens cleaner CD to clean the lens.If your player is skipping any discs at all though, then try purchasing a can of compressed air (available at Staples, or Wal-Mart). Open the CD drawer, or remove the cover of the player by removing the screws on the sides and rear of the unit. Then spray the can approximately 10" from the lens to blow any dust off of it.If it still doesn't work, you can opt to clean the lens eye itself, by using isopropyl alcohol, and a lint-free cloth to gently wipe the "eye". Then use a dry spot on the cloth to buff the eye clean. If the CD player is still not reading all the discs, then the lens or transport mechanism is faulty and would need to be replaced.
This could be a DIY ( do it yourself ), however not an ideal option as it would be quite expensive to replace the mechanism and still there is no guarantee that it would work for many years.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 24, 2010
SOURCE: my Aiwa cx-nma545 keeps turning off.
Your system is in 'Eco' mode. If you are in this mode, and go 10 minutes without playing a CD or cassette, it will automatically turn itself off.
Here's how you get out of 'Eco' mode:
1) Go to the jog wheel assembly
2) Press 'Eco'
3) Press 'Enter'
4) The display will show "Eco Mode On"
5) Immediately turn the jog wheel, to turn the status from 'On' to 'Off'
Posted on Jul 30, 2011
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
I have an old Aiwa NSX-V150M Compact Disc Stereo System. I cannot load CD's into the unit. Pressing the "Load" button causes the internal mechanism to cycle up and down 5 or 6 spaces and then a "CHECK"...
Hi! I also have an (old) NSX-V150M that does nearly the same, I suggest two problems on mine: 1) maybe the laser assy has to be changed because it doesn't detect the actual CD anymore and skips to the next one. 2) there is a tiny limiting switch on the moving platform that seems defective, or the rubber belt (?) is too stretched, so that it doesn't detect when the CD is in place from the changer. Then the unit starts again "CHECK"ing, as when the memorized list of CDs doesn't match the detected list of CDs. For the first one, maybe the Sony KSS210 or KSS213 spare part could be used, not sure of it. For the limiting switch, I have glued a match to keep it in place to keep the CD part quiet. Result: no more CD playing for now, but the unit doesn't "CHECK" anymore, and tuner and amplifier still work great. Need to look inside one of these days.
Jan 09, 2013 | Aiwa Audio Players & Recorders
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
Aiwa 3CD changer,Model no.CX-NK550HR, CD Player not working.CD Board is required to be renewed.Where can I get original CD board of above mentioned model
some one help me...my aiwa vcd component model no. CX-NK550HR suddenly dont open or power up... i think it have a problem in its transformer...what do u think???kindly send me a response on my problem pls.....
ym:jhongojar
email add; near.evil@yahoo.com
Nov 12, 2009 | Aiwa Audio Players & Recorders
Cant remove magazin with cds without changer is on power
Is there a pin-hole on the front of the cassette? If so, insert a paper clip into the hole to manually release the cassette.
Sep 08, 2009 | Panasonic CX-DP88 8-Disc CD Changer
Headphone jack size
Headphone jacks are either 1/4" or 1/8". If it's about the size of a pencil, its 1/4". If it's more like the size of your mouse wire, it's 1/8".
Apr 16, 2009 | Aiwa NSX-AJ20 CD Shelf System
Remote Code Aiwa CX-NA505u
Does not play cds properly skips like crazy volume knob sometimes goes louder when i turn it down dosent read all cds eather whats the problem?
Mar 24, 2009 | Aiwa VX-S205 Combo
Discs are skipping in my changer
cds skip irrespective of their positions as the reading lens is the same for all.
you can do the following
1)this seems to be a SERVICING problem with dust playing the spoilsport.
OR
2)buy a new disc (scratchless) , play it in all positions and com pare.
if it skips in all positions, call an electronic engineer who will replace /repair the delay circuit.
Apr 15, 2008 | Alpine CHA-S624 6-Disc CD Changer
460 people viewed this question
 Grubhead
Grubhead
