Question about Home
My dual flush toilet hisses after flushing what could be the problem i have a frenza dual flush toilet and dont know where to get the parts. The company who installed it about 2 years ago want to send 2 men out at $65 per hour to find out what is wrong with it. Unfortunately my husband and I are seniors and barely make $5 per hour. If I could find out what part I need I can have it repaired thank you caroltimmins@cogeco.ca
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
  • 129 Answers
SOURCE: My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Posted on Sep 28, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
  • 11 Answers
SOURCE: Pegusas toilet.
I have the same problem .... I took it apart and found that there is not any screws, nuts bolts, washers .... what it is (was) is a piece of lead (like a sinker on the end of a fishing line) attached to the end of the cable, yes the cable, that hooks into the handle and into the top of the flush mechanism - that yellow plastic tube )the cable goes through it) I was able to take it apart and repair the end of the lead weight with a split shot sinker BB - is the size I used. I also had to deform and cut some of the sinker away since the hole it sits in, is small. When I went to Home Depot to buy/get a repolacement unit, one store told me to call the manufaturer -- Foremost and gave me the number, I lost that piece of paper now that I have time to call again, I was left on hold for 10 minutes the first time. 1-888-256-7551 http://www.foremostcanada.com/warranty.php
I just called and pressed a few buttons, waited 2 minutes, got a live person, she asked me what was wrong, I told her that my handle was just spinning, she asked for my model number 131-926 (found on the inside back of the toilet) when I purchased it (make this up, within this year ... and yes you have the receipt - she never asked for it, just that I had one!) she took my address down and gave me a client number .... tada!
Posted on Dec 16, 2009
Water leaking into bowl
I have the exact same problem with the pfister toilet.Anybody with ananswer??
Mar 14, 2014 | Pfister VTP-E70W Kamato One-Piece Dual...
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
How do you put the toto dual flush parts back together
Very carefully!!!!!! Why would you take it apart not knowing how to put it back together again?????? Take pictures next time, after you call a plumber to put it back together again Humpty....
Apr 20, 2011 | Toto Aquia II Dual Flush Toilet
What is the problem when water is running on a dual flush toilet
water level set to high push botton rods not ajusted rite 5 year warranty on flush valve
1-800-459-4409 service and parts
Jan 21, 2011 | Toto Aquia II Dual Flush Toilet
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
Jan 21, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
My toilet cistern is continually hissing
Oct 17, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
My whip dual flush toilet leaks around the flapper
the flush neck must be pitted or someting, the part that the flapper sits on that needs to be replaced.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Home Logo
147 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
