Question about Olympia Mastertype 3 Typewriter
I have a olympia startype 3 and the carriage will stop typing and just set there and move the ribbon up and down repeatedly. Is there a problem with one of the circuit boards and who can you get to fix them, every repair person I have talked to says they do not work on Olympia any longer because they cannot get parts. I have four of these and they all do the same thing
  • Olympia Master
  • 3,594 Answers
The OLY STARTPYE 3 is the same as the NAKAJIMA Ae series there are probably broken wires in the carrier harness about 1" from the carrier connection. If you can get them to us I'm sure I can repair then.
DickyO
Cleveland Business Machines
216-241-0027
Posted on May 03, 2011
How do I increase the area where I can type?
Press margin release key, move carriage using backspace to where you want the left margin to be and press left margin set key. Repeat for the right margin, use space bar to advance the carriage and press the right margin set key instead.
Sep 10, 2014 | Olympia Startype 3 Typewriter
I have a Olympica Startype 3. I'm wondering if my printwheel is bad? My letters are broken and solid type.
Try typing on a multi part form with the impression switch at the largest dot, if the copies are good and the originals are bad the problem is the ribbon. If all are bad tou need a P/W.
DickyO
Apr 12, 2011 | Olympia Startype 3 Typewriter
When you start the typewriter, the pinting mechanism moves all the way to the left, stops, and it starts beeping.
Make sure the Print wheel is installed correctly. When the carriage goes to the lhs the print wheel should spin to find its home position... if no print wheel is installed it can give this symptom.
Mar 30, 2011 | Olympia Startype 3 Typewriter
Our Startype 3 typewriter now sticks when we type -- the tiny striker piece does not hit the character on the wheel consistently so we get jammed up or very light print... please advise a fix... Dori
Machine may be dirty inside....try cleaning the silver rod that the carriage slides across left to right inside the machine...then lubricate the shaft with a lightweight oil.
Jun 10, 2010 | Olympia Startype 3 Typewriter
Have no manual How do you set the margins on the compact S model
The Startype 3 is the same machine as the Nakajima AE-740.
Go to www.nadist.com and download the Nakajima manual for FREE.
Jul 28, 2009 | Olympia Startype 3 Typewriter
Accidentally set wrong 'language' code.
check the bottom left slider switch is not on PS, should be on 10 or 15.
Oct 06, 2008 | Olympia Startype 3 Typewriter
Operating manual for Olympia Startype
yes I need the operating manual for the Olympia Startype typewriter
Jun 18, 2008 | Olympia Startype 3 Typewriter
Olympia typewriter multi strike ribbon mode
Try code . or , one of them should change the ribbon spacing mode.
DickyO
Feb 26, 2008 | Olympia Startype 3 Typewriter
Olympia Startype 3
A couple things to check, lift the cover and make sure there is nothing obstructing the carrier from moving completely to the left. Also make sure your correction tape is not interfering with the print wheel. Try taking both the ribbon and correction tape out and see if the machine will go to ready. If this does not help let me know and we can check a couple other things, But try that first. John
Sep 07, 2007 | Olympia Startype 3 Typewriter
Does it make a grunting noise? If so, it needs a couple drops of oil on the main support shaft. Also check the indent setting. You need to use the code key to activate or deactivate the indent.
Aug 16, 2007 | Olympia Startype 3 Typewriter
Olympia Mastertype 3 Typewriter Logo
73 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
