Question about Cell Phones
Samsung I got the phone a little wet. Immediatley I took it apart and use the blow dryer on it. When it came back up I have the following message on my screen: Download startes Emergency @USB_ISR Image Invalid Bootblcok Version: r500_bb:AF16.8 Please help me and many others figure this out. Thank you Drew englecin@aol.com
  • 2 more comments
  • baby dee 21 Nov 28, 2008
    My phone got lose but before that it got wet & the screen show that message on it. I have no ideal on where its at now.
  • Anonymous Apr 04, 2009
    i threw up on my self....
  • geoff20893 Apr 05, 2009
    The phone got a little wet I took it apart to dry off and run a blow dryer through it and after I finished and turned the phone on it just says "download."
  • crudley Apr 20, 2009
    Phone went through wasing machine, dried it out, and the screen displays "Download". Would it be that the water caused a short that wiped out memory?
  • 59 Answers
Hello there. your problem might be some update your phone is under going if its not gone in a day ask an expert on how to eliminate the problem. thank you. bye!
Posted on Aug 04, 2008
Phone got wet - dried it out but no visuals - what can I do?
A phone Technician would best handle that. Most likely the circuitry would have gotten wet.
>A blow dryer May could have helped a little better after getting most of the water out.
Apr 02, 2016 | Samsung Cell Phones
Samsung galaxy lll got wet. Major functions seem to work, however, the microphone doesn't let you hear the other end of the call even though you have made a connection
i will give a little secret.Put your cell phone open in a recipient with a quantity of Rice, this will absorb the humidity by 24 hours. Please keep the rice cover all the cell phone. and try again.Of course after you take the cell blow with some gum dryer hair.
God bless you
Jul 30, 2013 | Cell Phones
My phone got wet just a little bit and ive tried drying it with a blow dryer and taking the battery out and stting it alone.what do i do? i only touched it while my hand was a little wet
the blow drier was a bad idea, any time electornices get wet, you should power them off if not already done so, then take them apart (battery and any other parts that are not going to ruin warrenty) and then just sit them out and let them dry naturaly, the heat from a drier could damage components, do not attempt to re power the device until you 100% know that it is dry on the inside to prevent short circuting
Apr 20, 2011 | Cell Phones
My Samsung M510 got really wet, i took it apart
my samsung shows half white screen,top half plus freezes on certain screen & shows static.Can u tell me whats wrong with it as im not sure if its a battery error or malfunction??
Jan 16, 2010 | Samsung SPH-m510 Cell Phone
How to flash a samsung behold
my phone got a sprinkled with water and i took the battery and sim card out and dryed it all with a blow dryer now i keep getting a message in red that says DEMSBL BOOT Loader for MSM6290 more than downloader V5.43 ????? what do i do ??? please help
Sep 07, 2009 | Samsung Behold Cell Phone
My phone got wet
Try removing the battery, using a blow dryer to air everything out in battery compartment. If there are any tiny screws or way to open up the phone itself, open it up, and blow everything inside there too.
Let it dry out completely and then see if it will work again. My guess is no, because once the circuits get wet, they are pretty much damaged and irrepairable.
Hope this helps at least some. Good luck!
Jul 31, 2009 | Samsung Hue (SCH-r500) Cellular Phone
I got my Palm Centro wet. I took the screws out
do not put your phone in ANY liquid, even rubbing alcohol! any liquid puts your phone at risk of corrosion in places you cannot see. even if it works fine now, that is no guarantee that there is not still small amounts of moisture inside that may still cause damage later. take your phone apart, put all the pieces of your phone in a ziploc bag of uncooked rice, and LEAVE IT IN THERE for at least 24 hours. having the battery in at all when there may be moisture inside puts your phone at risk for more damage. save yourself trouble later by leaving it alone in the rice for as long as you can. two days would be better.
Jun 26, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Dropped phone in water
SIM is probably bad or a little wet. but wait and let everything dry out and see if it works. Mine was soaked and the next morning worked fine. at least you probably won't have to buy a new phone.
Apr 28, 2009 | Samsung SGH-t229 Cellular Phone
Phone won't turn off
Wierd things started to happen to my son's phone when got it wet. I tried the tricks I found on the web. Things like: putting it in the oven to dry it out, and letting it sit for a few days. I ended up taking the phone completely apart. It was a little tricky, but since the water voided the warranty, I figured I had nothing to lose. It will a little bit of work, but I got it all apart. I figured it someone would assemble it, it ought to come apart. I found some 'corrision' on some of the flat ribbion cable connections. I think there was one for the screen and another for the keypad. After doing that, it has worked just as good as when it was new. It has been about 8 months since I did that. One thing I will caution, is becareful with the slide mechanism. May sure you see how it is put together. One of the springs popped out on me and it took a bit to figure it out.
Jan 18, 2009 | Samsung SGH-a737 Cellular Phone
Dropped in water
open the mobile phone and pls ur hands should be dry now open then the board and use a cooton swab dipped in very little (pure )gasoline and start to rub on the circuit board and let it dry ,, u have to be certain that all areas are covered and now assembnle it it will work
Jun 19, 2006 | Nokia 6019i
Cell Phones Logo
549 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
