Question about Poulan Pro Chain Saw 46cc 20"
When i start the saw up it starts up but shuts off when you hit the gas and also when it starts up it just shuts off. I don't know how to adjust it to make it run so i am asking how to adjust it. I have tried to adjust the hi and low but i still get the same thing is it like a carb on a truck turn the low and hi idle all the way off and then give them a 1 and a 1/2 turn or what. please help because i really need the saw. thanks for your help
  • Poulan Master
  • 2,239 Answers
The carb screws are fuel screws, not air screws, gently turn them both in ( clockwise ) onto there seats, now back off the L screw 1 1/2 turns, back the H screw off 1 turn, you will have to fine tune from there, start the saw, increase the idle screw so it will idle if needed, start by screwing the L screw in, the revs will start to increase due to the weakening mixture, it will eventually start to die as it is too weak, so at this point start unscrewing the screw 1/4 turn, rev the saw, it should pick up smoothly, if not increase the L screw another bit turn until it revs smoothly, now set the idle screw so it runs 3000 rpm approx, the H screw is the govenor, the more you screw it in the higher the revs, the max rpm should be set with a taco to 12500rpm, do not exceed this or it may seize, before any adjustment, replace the filter in the fuel tank, use fresh fuel, and clean the air filter.
Good luck.
Posted on Mar 28, 2011
My poulan 4018wt has been a hard starter from new. It started to act up out of the blue and started shutting off halfway into the cut and didn't always want to idle right. So I changed the spark plug,
I'd say the most probable culprit is the fuel.... I'd first try dumping the tank out, mixing fresh gas with the addition of a fuel stabilizer and start the saw. It'll quickly vent any old gas in the line and should begin to run fine with the new mix. If not, consider returning it to the service center for adjustment.
Never use gas that has sit on a shelf for months at a time as it becomes 'stale' (for lack of a proper term). Todays 'formulated fuel' can be a cause a bit of a problem for some small engines. Anytime you refuel, shake the can to remix prior to filling.
The oxygenated nature of the blended gas sometimes causes the chain saws to run a little 'lean'...meaning too much air to fuel ratio which could be a portion of your problem. A lean running saw will run hot and scoring of the piston or cylinder wall is possible. Some finely tuned professional saws need carb adjustments between the summer blend and the winter blend gas.
Mar 24, 2015 | Poulan Garden
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have just cleaned the carb and put new fuel line on this saw. I also put a new primer bulb and filter on it. Ican get it started and it will rev up and then die like it is starving for fuel. I bough this...
Ok first the plug gap is around .030". Next you have to have compression. With the sparkplug in you should be able to feel the "hard" spots while pulling the starter rope. The rope should not just pull out smoothly. Now for the carburetor. Start by screwing the hi and lo jets in as far as they will go. Gently screw them in, don't force them or you will damage the needle and seat. Now turn them out 11/2 turns each. The idle speed will be adjusted later. Make sure that the fuel is fresh and has the right amount of oil in it. Now start it up and let it warm up. You may have to use the throttle to keep it running. Adust the idle screw so that it will run on it's own. Now adjust the lo jet until you get the highest rpm, adjust the idle to keep it at a good idle. Now adjust the hi jet, you do this at full throttle until you get the hight rpm. Let it idle, now open the throttle, if it hesitates turn the lo jet out about 1/8-1/4 turns and try it again.
Aug 27, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need to know what carb screw adjustment need to be set at weedeater starts for about 4-7 sec then shuts down put new hoses on checked gas filter and cap checked out ok. i pump the ball about 10 times...
If there is a choke adjustment you should set that at full until the trimmer warms up, don't touch the gas. Then repull start at half choke, don't touch the gas either at this time. Then start at no choke, and then set your idle on the carberator with the adjustment screw. Also don't push the primer bulb so many time you will cause the spark plug to get flooded and drown out the spark, which is exactly what is happening.
Sep 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Hard to start! runs about three minutes and shuts down. reconditioned saw.
Clean Spark Plug or replace.
Drain fuel and fill with FRESH gas and oil mix.
Adjust carb.
Sep 10, 2009 | Homelite Garden
My poulan chain saw sat for about 2 yrs with gas in it. I emptied the tank, put new gas in it along with a carburator cleaner but it will not start. lost the manual for it and don,t know which position to...
Empty out the gas and replace with proper gasoline mixed with oil in the proper proportion. Always use a good quality 2-cycle oil that contains a fuel stabilizer.
To start the generic chainsaw, follow these steps:
1. Pull the choke all the way out
2. Press the fuel bulb serveral times to prime the carb - you can feel when the fuel flows into it.
3. Set the lock on the trigger to full speed.
4. Now, pull the starter rope until the saw sounds like it tried to start.
5. Press the choke in to the 1/2 way position.
6. Pull the rope until it starts.
7. Release the trigger lock and push the choke all the way in.
If starting it when it is warn, skip steps 1 and 4.
It is unlikely that the spark plug is the problem. If you replace it without properly setting the gap, you may make it worse. If you start trying to adjust the carb without knowing exactly what you are doing, you will make it much worse, You can try spraying some carb cleaner into the carb and pulling the rope to such the cleaner into the jets.
In the future, always add fuel stabilizer or oil with a stabilizer to you gas/oil mix. This prevents the varnishing caused by aging gasoline.
Jul 11, 2009 | Poulan Garden
Husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Jun 11, 2009 | Husqvarna Forest & Garden No.967012396 345...
I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
May 02, 2009 | Garden
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan Pro Chain Saw 46cc 20" Logo
194 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
