Question about Car Audio & Video
Hello i had a flat battery; leaving my 2007 toyota hilux radio in SEC mode; i have the pin number from the front of the radio.this was aslo fixed some 2 years ago at toyota service centre, it is a standard mps toyota radio. can anyone tell me how to fix this on my own?
  • 1 more comment
  • harry446 Mar 28, 2011
    hi
    it did not work; i have a very stanadrad toyota radio mp3; nothing chnged at all sorry. i think i may need to go to the service centre and pay the $60.00
    hi
    i am not sure if you got my message; it did not work. my car radio is a very standard toyota mp3 ; nothing at all happened
    the tune button is plugged for non use; if we are talking about the top node. the dial did not react at all
  • 11,800 Answers
1) To remove the security SEC warning hold down the "TUNE" button and then press "1"
2) Use the numbers 1 2 and 3 to type in the last 3 digits of your VIN number- press them as many times as necessary to display the corresponding code number.
3) Quickly hold down "SCAN" button, the radio will power off, then press the volume button to turn it back on.
Posted on Mar 28, 2011
  • 5,370 Answers
You will have to get radio re-programmed by the dealer.as the internal memory chip of the radio is got hanged and it has to be reset by the service device.The radio will be connected to service device and reset procedure will run and it will reset the memory and radio should work as normal after that.--------- This should help.Thanks.Helpmech.
Toyota hilux vigo 2014 radio and power window not working after removing the battery
I gather that you put the battery back in? You need to check all the fuses and connections and also unhook one of the cables on the battery for a minute and then reconnect to make sure a surge did not lock something in the BCM up.
Aug 18, 2017 | Toyota Cars & Trucks
Toyota 2007 hilux ute changed battery radio does not work
If you have an aftermarket radio there is probably a wire going directly to the battery and that wire has a fuse. These fuses are very sensitive. Fuse or Wire.
I hope this helps.
Oct 21, 2013 | Car Audio & Video
How do you enter radio code on 05 Toyota hilux
the battery was disconnected on the 07 hilux and the radio/sat nav just asks for the correct map disk to be inserted but the map disk is in it and it doesnt do anything...
Feb 18, 2010 | Toyota Vehicle Parts & Accessories
Lost code for 1996 toyota prado radio l had the battery replaced now the radio displays a sec sign
for our Toyota Prado 2001 01, after the battery had been removed SEC was showing on the cd / tape / radio display. To remove the security SEC warning, find the last 3 digits of your VIN number (under the hood) hold down the "TUNE" button and then press "1"
Then use the numbers 1 2 and 3 to type in the last 3 digits of your VIN number.
-I accidentally held down "auto" before holding down scan, I don't think auto has any part of fixing this (just an error on my part) but if the above doesn't work, you could try hold AUTO down after entering the digits then hold scan - just as I did.
SEC has now been removed, enjoy your radio!
Feb 08, 2010 | Car Audio & Video
Sec lock on readio 1994 toyota celica disconnected
call the dealer with your VIN number, they will call the manufacturer and call you back with the code, alternatively, look in your owners manual in the front and rear page, some times dealers write them in there, also look in the radio pages they may have written there as well. Good luck
Nov 19, 2009 | 1994 Toyota Celica
Code sec showing on radio screen
Take the car to a dealer and have the service manager look at the radio screen. Should be a no charge fix.
Jan 10, 2009 | 2003 Toyota Camry
Toyota Echo Radio Code Help - 2000 Model
Go into Toyota and take your registration with some form of Picture ID and for a fee they will be able to get you the code for that radio. Good Luck
Dec 10, 2008 | 2000 Toyota ECHO
Car Audio & Video Logo
2,498 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
