Question about Kyocera Mita Office Equipment & Supplies
Taskalfa 221 Memory full message problem when scanning (with scanner file utility) I have install scanner file utility on 3 computer, each of them have his own account. For 1 month there was no problem with the scan, i can scan 90pages by the adf in one time. Now when i try to scan i get this message after 5 pages pass : "Memory full", and the scan stop. I get this message on all the account (the 3 different computer) so i'm thinking that the memory is full on the copier, and i have already remove all of the scan in the folder were they go on each computer. Also i can scan one page without a problem, but no more than 5 .. Thank you for your help.
  • 6 Answers
SOURCE: Scanner - memory is full
A KM-2550 has 64 MB RAM built in. I believe less than 30 of it is for image storage. You may be able to lower your scan resolution.
Best solution is to add more memory. Look for a Kyocera compatible 100 pin dimm (don't buy from the manufacturer). It will read 16 MB to 256 MB sticks. You have to take out 6-8 screws holding on the part of the back the sticks out on the upper left. Make sure after installing you print a status page to make sure the memory was recognized.
Posted on Apr 17, 2008
  • 54 Answers
SOURCE: Unable to "Scan to PC" for anybody else, but me!
The Save number and the Registration Number must match, folder # will be same as save and registration number.
Posted on Jul 09, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    crayzeetrayn
    • 837 Answers
    SOURCE: when scanning document stops halfway through ADF
    Have you tried lowering the resolution of the scanned document?
    Posted on Nov 24, 2008
    • 19 Answers
    SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
    Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
    Posted on Jun 18, 2009
    Can I use Kyocera 180 as a scanner
    No, a TaskAlfa 180/220 series will not scan. The 181/221 series can have a scan card added as an option.
    Sep 17, 2013 | Kyocera Office Equipment & Supplies
    My scanner did work at one time but all of a sudden I am getting this msg No Scanner Options refer to device documentation! I dont have my documentation!
    User guide is here:
    http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=441142&targetPage=http%3A%2F%2Fbizsupport1.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc00461378%2Fc00461378.pdf
    Although I did not see anything in there about that specific error in there.
    I do know of a scanner utility that can diagnose and fix more scanner issues on HP all-in-one products. Worth giving it a try.
    http://h10025.www1.hp.com/ewfrf/wc/genericSoftware DownloadIndex?softwareitem=oj-45265-1&cc=us&lc=en&dlc=en&dlc=en&lang=en
    Instructions for use:
    Scroll down the webpage and in option 3 we have the 'Download Only' button. Click on "Download only" button in that page. When prompted, click Save and save it to the desktop of the computer.
    Download and install the HP Scan Diagnostic Utility to the desktop and double click it.
    After downloading the file, we need to run the file " Scan Diagnostic Utility_ver_1.5" to install the utlity.
    After few seconds, below screen will be displayed along with HP Scan Diagnostic Utility will appear on the desktop.
    Double click on "HP Scan Diagnostic Utility" icon and select the printer.
    After running the utility, we need to select the All-in-one from drop down list, then we need to select "Diagnose" option.
    After running the utility, we need to select the All-in-one (if multiple Printers are installed, we need to select appropriate one) and we need to select "Diagnose" option.
    If an error condition is identified with any of these components, a Red 'X' displays next to the item. If there are any Red X marks, click on Fix button.
    If there is no error condition, a 'Green' check mark displays next to the item. The utility is equipped with a FIX button to correct the error conditions. If there are any Red X marks, click on Fix button.
    Then you will receive dialog box with green and red checkmarks. If there are any RED X marks , we can select "FIX" option. And all red checkmarks should change to green checkmarks.
    Apr 04, 2011 | HP Officejet 5610 All-In-One InkJet...
    I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
    Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
    Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
    1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
    2. Type %windir%, then click OK.
    3. Double-click twain_32.
    4. Right-click Kodak, then select Delete.
    5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
    NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
    6. Double-click aioscannr.msi, then follow the instructions to remove it.
    7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
    8. Open Home Center Software:
    a. Select Scan Documents and Pictures.
    b. Scan a document.
    Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
    I hope this helps.
    Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
    I bought a new hp computer with Windows 7 OS. My hp Officejet 7310 now will not scan. The HP Solution Center that was downloaded with the HP Officejet All-in-One series Windows 7 driver disc (new, just...
    A full feature software and driver package for Windows 7 is not available for your product. However, the Windows 7 operating system installed on your computer contains a basic driver solution for your product. With the basic driver, some of the advanced product features are not available. You can print from a software program, and import and view images on a memory card, if your product has a memory card slot. With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. How to Scan a Document in Windows 7 By Greg Harvey The Windows Fax and Scan utility enables you to scan documents and pictures. Before you can scan documents and pictures, you must have a scanner installed on your computer. Your scanner must be listed in the Devices section of the Devices and Printers Control Panel window.
    To check to see if your scanner is properly installed, open the Device Stage. Choose Start?Devices and Printers. If Windows doesn't automatically find your scanner, you can manually add it in the Devices and Printers window by clicking the Add a Device button in the toolbar and following the wizard's commands.
    1. Choose Start?All Programs?Windows Fax and Scan.
      Windows 7 opens the Windows Fax and Scan window.
    2. Click the Scan button in the Navigation pane, then click the New Scan button on the toolbar.
      The New Scan dialog box for your scanner opens.
    3. Use the settings on the right to describe your scan.
      By letting the computer know what you're scanning, its color profile, and the type of file you plan to create, you enable Windows Fax and Scan to create the highest quality scan.
    4. Click the Preview button to see what your document will look like.
      Make any last minute changes.
    5. If you're happy with the preview, click the Scan button.
      Windows scans the document and presents you with an image of your document.
    6. Click the Save As button and complete the necessary information.
      Enter the filename, the type of graphics file you want saved, and then click the Save button.
    To automatically forward the document you've just scanned as an attachment to a new fax message, click the Forward as Fax button.
    The scan feature in the Windows Fax and Scan utility is set primarily to scan text documents. If you want to scan a photograph or other graphic, you're better off doing that directly within the Windows Live Photo Gallery.
    Read more: http://www.dummies.com/how-to/content/how-to-scan-a-document-in-windows-7.html#ixzz15JFYWJQ1
    Nov 15, 2010 | Computers & Internet
    The Panda antivirus keeps telling me danger I need to restart my computer, and when I do nothing changes, it still gives the same message
    Get rid of Panda, uninstall it and install AVG from http:\\free.avg.com
    Once you've done that run a full scan, and scan for spyware/malware also with a decent scanner like malwarebytes anti-malware
    Oct 29, 2010 | Encore Panda Antivirus Pro 2010 3 Users ...
    How do I scan an item and send a copy to a friendI am using a Photosmart C5280 printer
    Please follow the steps below to do a clean installation of your scanner.
    The first thing we need to do is remove any files that have been installed and start with a fresh installation.
    1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
    2) Select the HARDWARE tab, then the DEVICE MANAGER button.
    3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
    4) Disconnect the USB cable and close all open windows.
    5) Click on START, and CONTROL PANELS.
    6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on CHANGE/REMOVE.
    7) Restart your computer.
    DOWNLOAD
    Please follow the steps below to download and install your scanner in XP:
    1. Go to the website http://support.epson.com
    2. Under the SCANNERS heading select PERFECTION SERIES and then your scanner model.
    3. Under the Drivers & Downloads section select Windows.(Make sure it is the Epson Scan utility. Download the most current version of the Scanner Driver for your Windows operating system to your DESKTOP.
    Reinstall
    1) Double Click on the Epson1**.exe file that you downloaded to your DESKTOP.
    2) Click OK, Unzip, and then OK again.
    3) The installer will copy the files to the system. Click on FINISH when prompted.
    4) Connect the USB cable. Windows will tell you new hardware is found and complete the install.
    5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
    6) Your scanner is now ready to use.
    Use the following steps to scan with the Epson Scan utility:
    1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
    2. If prompted, select your scanner from the list of models and click OK.
    3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
    -LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
    -PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
    -FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
    -For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
    PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
    1. Click OK once settings are changed as desired.
    2. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
    3. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
    4. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
    5. Now you can use them in mail and send to your friend.
    Jul 04, 2010 | HP Photosmart C5280 InkJet Printer
    I have a kyocera cs-1650 and am trying to scan to pc. I have scanner file utility installed, yet it shows no connected scanners in the status box. How do I get scanner file utility to recognize and...
    You have to make a folder on you computer to scan to. you have to configure the scanner file utility with the path to that folder. You have to setup the scanner NIC with a sender ans a destination. The destination has to point to the PC running the scnner file utility by inputting the computer hostname or IP. The scanner nic can be configured with your web browser by putting the scanner NIC IP in the address bar. You have to make sure your firewall is not blocking the file scanner utillity. For more help go to www.gfbm.net.
    Dec 31, 2009 | Kyocera Copystar CS-1820 Black and White...
    Issue installing xerox documate 510 scanner using windows vista
    Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
    Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
    Kodak AiO 5500 scanning problems.
    If you are running Vista, you can still scan and copy by using Windows Photo Gallery.
    1. Click on files tab at the top in Window Photo Gallery.
    2. Click on import from camera or scanner.
    3. Highlight your scanner icon (eg Kodak 5500) then click import.
    4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
    Hope that helps.
    Chris (ziraffa)
    Jan 11, 2009 | HP Photosmart C4280 All-in-One InkJet...
    Scan copy to computer
    Please check the original software disk that accompanied the scanner. You should have the option to install a twain or twain32 driver at the least, which would allow you to scan from within a graphics program (photoshop, or even paint).
    Jul 04, 2008 | Epson Perfection 2400 Photo Flatbed...
    200 people viewed this question
    Top Kyocera Mita Office Equipment & Supplies Experts
    Kyocera HP Expert
    Adorjani Laszlo
    AAAA262430
    Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
