Question about Big Green Egg Grilling
Can you over heat the egg to the point that it is very difficult to open?
    Brigadier General:
  • 4,736 Answers
I have never heard of that happening. But, the lid of a Big Green Egg is heavy and some times the hinge springs either snap or get weak. Which makes it very difficult to open. But, sealing itself shut, because of high heat, I don't think so.
Posted on Mar 28, 2011
What's the difference between the "limit controls" & the "force controls" on Chamberlain garage door opener model 1245r?
Limit controls determine the maximum up and down point for the door, so that it doesn't keep trying to close when it's already all the way down, or continue to open when it's fully open.
Force controls determine how much pressure can be applied against the direction of travel before the door will sense the pressure and stop moving. Imagine setting a watermelon or egg in the way of the door when it's closing. If your force control is not set correctly, it will crush the watermelon or egg.
Nov 29, 2014 | Building Materials
Tip
How to cook the perfect hardboiled egg
Cooking the perfect hard boiled egg can be surprisingly difficult.
Start by filling a pot with lukewarm water and placing it over a very low heat.
This doesn't need to be the lowest flame setting on your stove top but it should be low.
A good comparison is the flame should be as high as you would have it if you were cooking rice.
Gently place the uncooked eggs into the water.
Pour about a tablespoon of vinegar into the pot. The vinegar will not alter the flavor of your eggs, it will just help the shells peel right off of them when they are ready.
Do not cover the pot.
Keep an eye on the pot for when it boils.
Once the water has come to a rolling boil set your timer for 14 minutes.
Once the timer sounds, remove the eggs with a slotted spoon and place them in a bowl of cool water.
Eggs peel best if they are cold so if you need to peel them right away, do so under a stream of cold water from the faucet. If you can wait, put them in fridge in a closed container so that the sulfur smell doesn't permeate other foods in there. When you're ready to peel them, simply take them out and watch as the shell is removed easily, thanks to the vinegar!
on Oct 07, 2013 | Cooking
How are you supposed to heat up the green egg
There are you tube videos. I temporarily take daisy vent cap off top of egg, open bottom vent door wide open, light lump coal 2-3 spots with a loof lighter (from ace hardware) and then close lid. I have one section of galvanized dryer vent from Lowes that I stick on top which accelerates preheating of egg. Once the temp gets to 500, I remove the section of vent by grabbing it with a glove or hotpad. Wait a minute or two for smoke to die down. Place daisy back on top and close bottom vent door down to 1/2" and close daisy 1/2 on top and this should drop temp to 175-250. Use fine adjustments 1/6-1/8" until desired temp is reached. Your food can go on at any time after removing dryer vent. Just burp lid by slightly lifting to allow any heat burst to escape. I also have a gas conversion that works awesome. I just add a small smoke ox over burner that provides enough smoke on front end of cooking process. Advice- keep the butts and ribs on for 6 hours.
May 01, 2014 | Big Green Egg Extra Large - XLHD...
I'm trying to make egg rolls but I'm not sure what to put in them? Please help
Ingredients
  • 1 pound ground pork
  • 1 teaspoon ground ginger
  • 1 teaspoon garlic powder
  • 1 quart peanut oil for frying
  • 2 tablespoons all-purpose flour
  • 2 tablespoons water
  • 2 cups shredded cabbage
  • 2 ounces shredded carrots
  • 8 (7 inch square) egg roll wrappers
  • 2 tablespoons sesame seeds (optional)
Adjust Servings recipe yields 8 servings Directions
  1. Season pork with ginger and garlic powder and mix thoroughly. Heat mixture in a medium skillet, stirring, until pork is cooked through and no longer pink. Set aside.
  2. In another large skillet heat oil to about 375 degrees F (190 degrees C) or medium high heat. While oil is heating, combine flour and water in a bowl until they form a paste. In a separate bowl combine the cabbage, carrots and reserved pork mixture. Mix all together.
  3. Lay out one egg roll skin with a corner pointed toward you. Place about a 1/4 to 1/3 cup of the cabbage, carrot and pork mixture on egg roll paper and fold corner up over the mixture. Fold left and right corners toward the center and continue to roll. Brush a bit of the flour paste on the final corner to help seal the egg roll.
    1. Place egg rolls into heated oil and fry, turning occasionally, until golden brown. Remove from oil and drain on paper towels or rack. Put on serving plate and top with sesame seeds if desired.
Apr 20, 2014 | Cars & Trucks
Coals are smouldering but they are not getting hot. getting a lot of smoke but temp not moving up. top and bottom vents are open all the way.
If you are rting to use the Egg as a grill instead of a smoker. The coals will heat up quickly if you raise the lid and leave it open. The way you were trying to do it is for smoking or baking not grilling. Leave the bottom vent open until the coals are really hot, then damper it down a little.
I hop this helped you and Happy Grilling. Thanks for choosing FixYa.
Jul 23, 2011 | Big Green Egg Grilling
Took a 500 m ile road trip and my battery would get over heated smell like rotten eggs and at one point shut down my whole bike. Had to replace battery 4 times before I got home. What could be the problem?
Not knowing what kind of bike you have, I can't tell which parts to change, but it is definately OVER-charging. the rotten-eggs smell is battery acid boiling(so to speak) out of battery. Have voltage regulator checked first tho
Jun 17, 2010 | Motorcycles
I have a 2006 Suzuki Forenza that has a water leak
Hi Hit,
Before doing anything yourself to the vehicle, definitely check the coverage of the warranty. Maybe on of my fellow experts has the details on that.
If it turns out to not be covered, here is an inexpensive fix. Get an egg. (I'm serious, I have done this and seen it work with my own eyes, so hear me out)
With the engine cool, break the egg (not the shell) so it goes into the radiator. Top it off with water and cap it.
Start the engine and let it run until it's thoroughly warmed up.
As the water heats up, so does pressure. Water will begin to shoot out of the pinhole you described.
At the same time the water will begin to cook and hard boil the egg causing it to solidify.
As the coolant circulates, eventually one of these pieces of egg will be caught in the escaping flow of water and jamb up against the hole. As the pressure becomes greater, it will be partially expelled through the hole. As the heat cooks it more, it expands more and becomes leathery forming an effective plug.
Keep in mind, by the time the egg has made one trip through the water pump, it's in a thousand pieces. Small enough not to inhibit the radiators function, large enough to plug the hole.
Hope you find this very helpful
Mike
Oct 04, 2009 | 2004 Suzuki Forenza
Big green egg does not heat above 600
I'm not sure why you would want your BGE to go above 600 but here goes. Are you using a full load of hardwood lump charcoal (to the top of the fire ring...lump because it burns hotter)? Do you have the draft door and the daisy wheel wide open (may even want to remove the daisy wheel)?
Jun 25, 2009 | Big Green Egg Grilling
Microwave not turning on after egg explosion
repair door target wont accept return or repair under warranty due to damage by owner
Jun 16, 2017 | Danby DMW1153 Microwave Oven
Grilling Logo
254 people viewed this question
Top Big Green Egg Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Johnathan Lence
Johnathan Lence
Are you a Big Green Egg Grilling Expert? Answer questions, earn points and help others
