Question about Sony HVR-Z1 Mini DV Digital Camcorder
What is the best HDV1080i 50 settings for finale cut pro 5? My easy setup wont let me log & capture.
    Problem Solver:
  • 13 Answers
It complete depends what you are recording in! PAL or NTSC? and how many frames... FCP is customized to your camera settings, match them up and then capture away!
I capture mine using a PC because then you can play around with both MAC and PC editing platforms as MAC captures are encrypted to only run on MAC.
- Scott
Posted on Mar 29, 2011
JVC GY-HD100 is unable to capture to final cut pro. It shows "no communication" in the log and capture window. But It will capture useing IMovie with no problem. This creates an extra step in my...
You should select the Easy Setup preset that matches the cameras output before capturing.
You may need to start a new project for the Easy Setup to take effect.
Mar 03, 2011 | JVC GY-HD100 Mini DV Digital Camcorder
I can't initialize on FCP
If you are capturing HD, go into the menu > IN/OUT REC > i.LINK CONV and set it to off, and A/V->DV OUT to off. Go into FCP and go to the File Menu and select "easy setup". In the easy setup menu set the "Format" to "HDV" and set "Use" to HDV - 1080i60. Click "Setup". Now go to File > Log and Capture (command-8). You're now set to capture. Just queue your tape and hit "Capture Now" or set in and out points and capture "Clip".
If you want to capture SD footage, then on your Sony unit, go to the menu and set the i.LINK CONV to "on". In the easy setup menu you will want to set "Format" to "NTSC" and "Use" to DV-NTSC".
Sep 26, 2008 | Sony GV-HD700 HDV VCR
Tip
Final Cut Pro X Review-No Log and Capture or Log and Transfer?
The newly released Final Cut Pro X is now a hot topic, especially among the FCP 7 or 6 users. The UI of FCP X is different from the older versions. The style change is somewhat like how Adobe Premiere Pro CS4 differs from the older versions. In the other words, it is from grey to black. Of course, Adobe Premiere Pro is different form FCP. <br /><br /><b>How would FCP X change the video editing on Mac?</b> <br /><br /><b>- No Log and Capture , Log and Transfer</b>: <br />With FCP 7 or below, the Log and Capture option is to import tape-based videos, while the Log and Transfer option is for file-based camcorder videos. If you have mini-dv like Sony HDR-FX1S, you may need another tool to capture and save videos as a file, and then import to FCPX. <br /><br />For videos from file-based camcorders, the process is like working with iMovie. The Camera Import window should pop up when camera is connected to Mac for you to select clips. Then click Import Selected, or the like button to load videos. Even though FCP X is supposed to import AVCHD files in .mts or .m2ts format, there are still users reporting the problem. If that is the case for you, you may need to transcode AVCHD to QuickTime MOV for FCP. Aunsoft <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Mate for Mac</a></b> would help you make the videos compatible to FCP X. <br /><br />If you use Canon XF100 to shoot videos in .mxf format, or other camcorders with MXF files, just try Aunsoft <b><a href="http://www.aunsoft.com/video-converter-mac/">Video Converter for Mac</a></b> to see if it works for your .mxf video footage. <br /> <br /><b>- <a href="http://www.aunsoft.com/news/final_cut_pro_x_review_-_no_log_and_capture_or_log_and_transfer.html">No transcoding to ProRes</a></b>: <br />As it is known that the videos imported via Log and Transfer would be transcoded to Apple ProRes. User should wait for the transcoding before editing. It is said that Final Cut Pro X would grant you access to your material right away, saving a lot of time. <br /><br />Actually, there is also timeline for <b>editing in FCP X</b>. But the layout is different from the previous versions. The audio would be snapped to the video. You may find out more interesting features and get used to it.
on Jul 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut...
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed.
If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac.
Tips:
Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit.
Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks.
Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter
Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up.
Step 2:Load Kodak video files
First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book.
Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter.
Step 3:Select the output format and destination
Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location.
Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location.
Step 4:Start the conversion
After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion.
Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro.
Step 1:Import Kodak videos to Final Cut Pro
Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project.
Step 2:Edit Kodak video in Final Cut Pro
Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline:
One: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Two: Add transitions
For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Three: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
on Sep 17, 2010 | Computers & Internet
When ever i try to capture audio through xlr
whic soft ware are you using with blackmagic board Final cut or adobe primier
in mac go to system priferences and check for blackmagic is it set ok
and in pc go to controll pannel and you will find the blackmagic utilities please check also the setting nd also check the setting in priferences of the adobe primer and easy setup and capture setting in log and capture in finalcut if every thing is ok please download the latest software driver for the blackmagic board and install it it will *** a firmware upgrade and every thing should be cool .....
which board decklink extreem or the older one?
Apr 18, 2010 | Blackmagic Design DeckLink Extreme...
Tdk sony dvm60 miniDV tape not playing in final
HI please check your easy setup in tyhe fcp and set it as pal or ntse dv and should get the video in
Mar 02, 2010 | TDK DVM60 Mini DV Tape
Trying to capture video from a sony dcr-dvd610 to final cut pro. How do I do that?
Connect your camera with the fire wire to your mac and choose easy setup a dv and u shold get the video in to capture
Feb 22, 2010 | Sony DCR-DVD610 DVD Camcorder
Unable to
HHHhhhmmmm. I'd suggest the DV mode and if you camera has the option to output DV as letter box select this, as it is a faster version to edit with (due to compression of HDV). I don't know the camera but VTR is just the playing mode, so play the file you want while trying to connect. Is the signal coming from tape? If it is catured to the harddrive of the camera you will need to import not capture.
USB does not support video, USB2 maybe.
I
Jan 11, 2008 | JVC Everio GZ-HD7 Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Sony HVR-Z1 Mini DV Digital Camcorder Logo
73 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
