Question about Exercise & Fitness
I have a Schwinn 6100P treadmill that is displaying an error message. What should I do to fix the problem, or find out what the problem is?
4 Suggested Answers
  • 67 Answers
SOURCE: manual for Schwinn 1600 Treadmill
You can try
E-mail: customerservice@schwinnfitness.com
Phone: (800) 868-5764
Customer Service Hours:
Monday-Friday: 6AM - 5PM PST
Saturday, Sunday: Closed
Posted on Feb 27, 2010
Testimonial: "quick response and good solution advice of next step in finding a solution"
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
Robert Braun
  • 77 Answers
SOURCE: Belt slipping on Schwinn Treadmill 5620P looking for local repair zip code 97405
Look for a repair person in your area at Treadmill Repair
If you don't see one there, and find a good one somewhere else, please submit them to this directory.
Posted on Nov 18, 2011
How to fix Error Code E3 on Schwinn 6710P treadmill
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jul 30, 2015 | Schwinn Exercise & Fitness
How do I fix error 3 on schwinn treadmill
Feb 25, 2015 | Schwinn 6100/6300 Walking Belt
Safe key/lock out error
Mine has the same error, have you found a fix?
Mar 04, 2014 | Schwinn 840 Treadmill
Precor treadmill code e3 is on
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
E-2 message on schwin 420
You may be able to reset the main board by detaching the ribbon connector, then reattaching it. Unscrew the four screws that hold the display panel, and you will see a ribbon connector and a round connector. Gently squeeze the tab in the center of the ribbon connector and pull it off. Wait a couple of minutes, then reattach the connector by gently pushing it into the socket. The display should show a boot-up process and then the normal blank screen with the prompt to select user. If the E2 error returns, repeat the process. If this procedure does not reset the board, you will need to contact Schwinn about possibly replacing the board. You can contact them by going to Schwinn.com (http://www.schwinnfitness.com/schwinn_fitness_us/customerservice.jsp) and select the "email us" link or call the 800 number.
Jan 30, 2013 | Schwinn 420 Elliptical Trainer
Error message reads: Pace error #1
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed.
These errors messages almost always indicate an upper console problem when they are consistently displayed. Failures causing these error messages to be displayed are rare.
If the error message is consistently displayed when the unit is powered up, the upper console should be replaced.
May 23, 2010 | Precor 9.21 Treadmill
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
Exercise & Fitness Logo
175 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
