Question about Rowenta Perfect Iron
Mold in water reservoir
Hi! I have a Rowenta Perfect iron, model number DX9800. I have had it for 1 1/2 years now. I have mold growing in the water reservoir and would like to know how to clean it or take it apart and remove the mold. I have only used tap water and have been using the same water in a number of different irons for 14 years now. Thank you for the help! My email is Brendanmhn@yahoo.com. Thanks a lot!
    Problem Solver:
  • 18 Answers
Run a couple of cycles of white vinegar through the iron allowing it to steam out. The odor may not be the most pleasant but it will clean out the mold as well as any build up that accumulates on the elements. Make sure you run two more cycles of just plain water through the iron on some scrap fablic or an old towel as any of the loose debris will come through the steam holes. After doing this you will find that it runs smoother than ever!
Posted on Aug 04, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: Mold
First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
Posted on Dec 20, 2008
My rowenta progressive iron is leaking dark black water from where the cord retracts. What is causing this. Where is black water coming from?
The mountains of Mt. Fuji have blessed you. Just kidding, have you ever dropped this iron? Mold may be growing where there is a leak in the holding tank. Water and electricity do not mix, time for a new unit.
Jun 18, 2014 | Irons
I own a Rowenta Steamium DW9080 steam iron. I need a replacement plastic door for the water reservoir. The iron is functional and I do not feel it necessary to purchase the entire handle and cord...
Not familiar with that newer model, but here is the local dealer who is most helpful in California:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Aug 29, 2011 | Rowenta DG-980 Iron
Iron drips water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Apr 13, 2010 | Rowenta Perfect Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
Water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Mar 14, 2009 | Rowenta Compact Steamer - White
Rowenta Iron DZ6700
Try using different water...
heatman101
Sep 11, 2008 | Rowenta Perfect Iron
Mold
Aug 04, 2008 | Rowenta Perfect Iron
Its gone off!
The green light indicates the unit thinks it is out of water. Take of rewervoir; make sure the inlets are not plugged. Open the little plug on side, clean tank w/ clear water only, and shake out all water completely. Put it all back together, but leave reservoir off. Turn on and run unit "dry". Your should hear a "flutter" sound as the unit trys to pump water from missing reservoir, the heater/steamer should be sizzling hot & pressurizing. THEN the green light if ome ON, asking you to switch it off, refill & install the water reservoir. If things don't happen in that sequence, you should be able to determine what is wrong.
Dec 27, 2007 | Rowenta Perfect Iron
Rowenta Perfect Iron Logo
1,322 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
