Question about Konica Minolta Office Equipment & Supplies
Service Error saying Polygon MOT 0300 (Engine fatal error)
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
CompuGuy44
  • 432 Answers
SOURCE: fatal error 141
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum. Did you already get this fixed?
Posted on Jun 25, 2007
  • 78 Answers
SOURCE: SERVICE CALL 188 : FATAL ERROR
Service Call 188: Error: Sub-CPU Communication Error
1- Check the connection of the S2M board.
2- Replace the S2M board.
If the problem does not go away after a reboot you'd better call Oki (it should have a 3 yr. waranty) or an experienced oki technician.
This is not something you should want to fix yourself. The replacement of the s2m board is not an easy task (even for an experienced mechanic)
Posted on Oct 09, 2008
SOURCE: SERVICE CALL ? 980 ? Fatal Error
I was able to reset my Fatal Error 980 code on my C5800. There is only two wires coming from that connector and not four at the bottom of the fuser. That is pin 2 and 3. 4 and 5 is still the fuse but there are no wires there, just the 2 pins. What you have to do is make a fuse by connecting pin 4 and 5 together with a piece of wire and break the wire after a few seconds after powering up. This will reset the Fuser counter back to 100%. DO NOT DO THE NVRAM RESET, THAT WILL ERASE YOUR NETWORK FEATURE. Here is the step by step of what I did.
1)Take out the Fuser and lay the two blue levers flat and remove them.
2)remove the two silver screws and separate the casing.
3) Remove the two black screws from the connector at the bottom of the fuser closest to the edge.
4)Unravel and loosen the wires so you can pull that connector out a few inches so you can get a couple of wires in there. You will see what you need to loosen to get the connector out far enough, really easy.
5)Insert a wire into each of the two holes on the back of that connector. Its pretty simple to see where they go, 2 and 3 have wires going in, 4 and 5 dont which is the fuse. After you get the wires in the 2 holes, check for continuity from the end of the wires and the terminals if you can. Make sure the wires are long enough to hang out the case. Use the thinnest wires you can find.
6)Run the wires out of the case and put the case back together and put the fuser in. Twist the two wires together and power up the machine. As soon as you here the first motor,which is about 5 seconds, pull the wires apart and BAM, you just reset the fuser back to 100% and cleared the "980" Fatal Error. You could always put a miniature fastblow fuse in instead of using the wires but that would be tedious to me.Good luck
Posted on Jul 12, 2009
SOURCE: OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Posted on Jul 27, 2010
Service call 0300 polygon mot
Replace the print head which houses the LASER
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 01, 2014 | Konica Minolta PagePro 4650EN - Printer -...
Error code 0300 on disk drive A
0300 Flexible disk drive (A) boot error POST has detected the flexible disk drive (A) reported an error during its self-test.
To correct this:
1. Verify a diskette can be properly inserted and removed from the flexible disk drive.
2. Verify the flexible drive type configured in the Setup utility matches the flexible disk drive installed in the HP Server.
3. Verify all data cables and power cables are firmly connected.
4. If the problem persists, your flexible disk drive may need to be replaced. Contact your service representative.
Jul 12, 2012 | HP Vectra VL800 PC Desktop
KONICA MINOLTA PagePro 5650 error code of 0300 Polygon MOT
Polygon motor is inside the print head where the machine LASER is located the motor spins around 35,000 RPM. Moving the LASER beam across the drum with image. Sound like you need a new print head. Try the below web sit for a start.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 09, 2012 | Konica Minolta PagePro 4650EN - Printer -...
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
The motor lock signal is detected for 6sec
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
Getting a E2 error on Kyocera FS-1700+. Any ideas?
this service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Oct 06, 2009 | Office Equipment & Supplies
My Sharpe Al-1553 keeps flashing L and won't work
This is a fatal error with the scanner. It is most likely to be a power supply or positioning error with the scanner not having returned to the home position or the positining sensor. You will need a service engineer call to rectify this.
Sep 24, 2009 | Sharp AR-M205 Copier
Miles to kilometers
You will need to contact VOSA (Vehicles operating standards agency) on 0300 123 9000, they should be able to inform you on the steps they need to take forward with you in order to have your MOT certificate rectified.
Aug 23, 2009 | 2006 Cadillac SRX
Konica Magicolor 5430 DL Fatal Error Code: 0300H
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
Sep 11, 2006 | Konica Minolta magicolor 5430 DL Laser...
1,465 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
