Question about Microwave Ovens
Hello I have a problem with mi Nodor TC64C3 because its blocked. When I pulse to start all the fires represent the letter L. Can you help to me please? Thanks for your attention. hocessss@gmail.com
Why is there another diode across the cap terminals?
That is a high voltage diode for blocking backwards pulses from magnetron, very harmfull for internal components. Cannot be checked with normal instruments. If is not damaged/blackened, leave it there.
Sep 11, 2017 | Microwave Ovens
A small fire started inside the oven. Only the glass broke everything else seems fine. Can I continue using it.
Maybe, maybe not.
You can probably find a replacement glass tray at a Good Will store.
I don't think I'd run it indoors any more. I'd set it on a couple of cinder blocks in the middle of my concrete driveway and hook it to a long, heavy duty extension cord.
Wear a face shield and stand back at least 10 feet after pressing the start button.
You should go to YouTube and search "Can you microwave that".
It's a series of videos.
Feb 26, 2015 | In Microwave Ovens
No help from Sears!
door indicator is the microwaves way of telling you the door isnt closed. does it run at all if it doesnt its probably a door switch. theyre there as a fail safe because your microwave shouldnt run with the door open
Jul 24, 2012 | Kenmore 62702 Microwave Oven
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
I purchased a hinari s/s microwave 77505883999 from tj hughes but it had no manual with it or the glass turntable and ring for inside microwave so they told me to go online and put in details of micro and...
Are you sure the number you have given is the model #? It looks more like a serial number. Most of the Hinari model numbers start with letters (eg. MX or EMX)
I found a website in the UK that sells parts for Hinari Microwaves ... > http://www.espares.co.uk/search/microwaves/hinari/p/1095/1032
Hopefully that helps...
Aug 08, 2011 | Microwave Ovens
I have the west bend 56870 the prgramable coffee pot and I never got a manual with it and I have no idea what the red light or yellow light is or even how it works send me instructions and itll be well...
Customarilym RED represents there is power and the ubit is on. Yellow/amber would indicate ubit is preheating the water in the resevoir and once heated properly, a green light should appear. Check all around the unit for a master on/off switch. Make sure it is on. Now, The timer is your actual start/stop controls. It should start at the time you set for brew and shut off at a predetermined time so it's not left to burn dry.. Sometimes, or more often than not this off setting is regulated by a temp sensor or timer factory set. I don't have a manual so I hope this helps. Remember, the setting you make is the setting it starts doing anything. Good Luck. I'm sure yoou will appreciate it once you get it to fire up. -Ned_
Nov 16, 2010 | Microwave Ovens
It catches on fire, through the center turn table.
NOTHING in a microwave should ever be on fire. Depending on the damged cause by even a small fire, the repair may be involved and costly. Inspect stirrer motor by removing bottom of microwave with power off. Note damage and replace stirrer motor and wiring harness as needed along with turn table drive block. Check to make sure all connections with all wires are sound with no exposed copper wires or shorts of any kind. Test always using a cup or bowl of water.
Jul 02, 2009 | Microwave Ovens
GE XL1800 (JVM1851SH06) Smoke
It all depends on what is generating that smoke..Where there is smoke. there is cost associated with it.. By virtue of diagnostic time or component replacement or both..If your micro is a potential fire hazard then don't compromise your safety. If your warranty JUST expired, you might be able to convince the service people at the place you bought it that it is defective.. and they just MIGHT surprise you by replacing it free. Why not take a shot at it? In fact, if they try to adhere to the letter of the date. then get LOUDER and LOUDER in front oif as many customers that you can.. In some cases, you might be better off talking directly with the dept manager insead of the normal service reps.. Good Luck.. Be Safe...
Oct 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Model number is NNV629MBBPQ.
To lock, press Start three times.
To unlock, press Stop/Cancel three times.
You can download your owner's manual here. You will need the free Adobe Reader to view or print it.
Other UK models can be found by searching for your model number (without the suffix letters) here.
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Jul 28, 2008 | Microwave Ovens
Food Processor Mod. # FP1445
I hope you are using a bowl to catch the food...?
One thing you can try is to cut out some plastic from a blister-pack or other type of toy-package and tape it onto the end of the chute. This will act somewhat like a doggy door flap. This will certainly slow the food down as it enters the bowl.
Mar 29, 2008 | Microwave Ovens
Microwave Ovens Logo
109 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
