Question about Bosch Washing Machines
Can i know where is the compartment where the keys or coins can be retrived?
    Brigadier General:
  • 6,277 Answers
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 28, 2011
I have a speed queen commercial washer and a quarter is stuck in the holder how do you release it
is it a slide coin mech? If so
7/16 top center of service compartment
is the slides retaining rod
Once you have access to the coin mechanism.
the coin release will move slightly outward allowing the coin to fall into the return shoot
Jan 12, 2018 | Speed Queen Washing Machines
Changing battery motherboard
Gciappa,
Dell Support > Inspiron 1520 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins1520/en/sm/index.htm
Click on Coin-Cell Battery in the right hand list.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft static free cloth on the table you're working on. Helps prevent scratching the table, and laptop.
Turn the laptop over, Battery Compartment facing away from you.
3) Remove the Memory Compartment Cover,
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/html/about.htm#wp1175774
(Number 2 - memory module/coin-cell battery compartment )
The RTC Battery is that small plastic 'bag', that has a Red and White wire coming out of it, and ending in a small white plug connector.
(Real Time Clock Battery. Term coined now for CMOS Battery )
Replace battery, close cover, reinstall main battery, and AC adapter.
Regards,
joecoolvette
Nov 04, 2012 | Dell Inspiron 1520 Motherboard
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Locked
    If the calculator has locked up you should perform a reset.
    1. Press and hold the [C] (ON/OFF) key
    2. Press and hold the [LN] key (third key from the left on the top row).
    3. Release both keys simultaneously. T
    4. The calculator should display "0.00" (if the number of decimal places is set to two.)
    If that does not bring it to life you should perform a full memory reset
    1. Press and hold the [C] (ON/OFF) key.
    2. Press and hold the first key from the left ( the Square root x key) and the first key from the right (the SIGMA+ key ) on the top row.
    3. Release all three keys at the same time.
    4. Calculator should display "ALL CLr".
    5. To clear the message press the [C] (ON/OFF).
    6. The calculator should display "0.00."
    If the calculator does not respond as expected,
    • Remove the batteries, and
    • with a metallic coin (and what coin is not metallica) short-circuit the calculator's electrical terminals.
    • Maintain the coin for about ten seconds.
    • Replace the batteries (preferably fresh ones) respecting the diagram inside battery compartment.
    • The Calculator should display "ALL CLr".
    • To clear the message press the [C] (ON/OFF).
    • The calculator should display "0.00."
    If the calculator does not respond to the foregoing procedures, remove the batteries and leave them out of the calculator for 24 to 48 hours to drain capacitors.
    If it continues to malfunction, it will need to be repaired. One repair shop in Pennsylvania, USA has a website at http://www.fixthatcalc.com. You should contact them.
    Apr 11, 2010 | HP 20s Calculator
    Change the number of coins to operate
    you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
    Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Hp20s has locked up
    Hope it helps.
    Thank you for rating the solution.
    Nov 05, 2009 | HP 20s Calculator
    How do I get the batter cover off a Leapster?!?!?!?!?
    OK, after nearly breaking my daughter's leapster I have figured it out.
    Use the coin and twist the little screw up. Then with the screw part closest to your chest, SLIDE the cover off AWAY from your chest. The batteries are located on the undercarriage of the cover. It takes "4" AA's
    Hope this helps everyone!!!
    Amy Rocka
    Nov 15, 2008 | Leapster Learning System
    HP 20S Calculator
    If it continues to malfunction, it will need to be repaired. One repair shop in Pennsylvania, USA has a website at http://www.fixthatcalc.com Here is the link . You should contact them.
    Hope it helps.
    Sep 03, 2008 | HP 20s Calculator
    Washing Machines Logo
    12 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
