Question about Intel Motherboard
Where do I connect the SATA power cable to on the motherboard
    Scholar:
  • 109 Answers
Only the SATA data cable connects to the motherboard, the SATA power cable is connected to a cable from the Power Supply Unit (PSU) if you do not have any of the SATA power cables on your PSU you can get MOLEX to SATA power cable converters (MOLEX is the "fan power connecters")
Posted on Mar 28, 2011
Testimonial: "Quick answer to my problem. Much appreciated"
Connections to the hard drive
The Harddrive is a SATA unit.
Uses a SATA data cable, and a SATA power cable.
SATA data cable, and connector on motherboard, example;
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Between the SATA data cable connector, and the SATA power cable connector; the SATA data cable connector is the shorter of the two in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins.
The connector end used on the harddrive side, and optical drive side, (CD/DVD drive), is usually a 90 degree Bent Elbow.
The connector end that plugs into the motherboard, is a Straight connector.
NOTE* Color of connectors does NOT matter.
Most of the time the SATA data connectors on the motherboard, are different colors.
This is to help discern what number of SATA data connector it is.
Four SATA data connectors on the motherboard?
SATA 1, SATA 2, SATA 3, and SATA 4;
Or:
SATA 0, SATA 1, SATA 2, and SATA 3?
SATA 0, or SATA 1, is usually reserved for the Harddrive.
The Primary harddrive with the Operating System on it.
(Unless you have harddrives set in a RAID configuration)
DOES NOT MATTER WHAT SATA DATA CONNECTOR, you plug into, on the motherboard.
Want to plug the harddrive into SATA 3, or SATA 4?
Go ahead.
NO matter what SATA connector on the motherboard that you plug into, BIOS will find the harddrive.
Note the L-shape in the connector.
Has to line up on the L-shape on the harddrive, optical drive, or motherboard, SATA data connector.
There is usually a lock on the connector. This you may not see.
Sometimes there is a little 'bump' on the connector. Depress with the thumbnail to install the cable, or remove.
This is an example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
IF, your SATA harddrive has a provision for plugging in a SATA power cable, AND a 4-pin Peripheral power cable; ONLY plug the SATA power cable in.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Using BOTH types of power cables will BURN the harddrive up.
May not happen right away, but I assure you it will happen.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/SATA
Dec 10, 2012 | Acer Aspire X1 AX1470-UR11P Desktop PC...
Tip
How to connect your hard drive to your motherboard The first thing you have to...
The first thing you have to figure out is what type of hard drive you have, a PATA or a SATA drive.
PATA = Parallel ATA
This type of drive uses the older IDE connections. Most of your current motherboards still have aleast one IDE connection to support the ROM drives on the market that have not moved over to SATA connections but you can still connect a hard drive to this connection if needed. The thing to keep in mind is that you can only connect 2 IDE devices to one IDE connection on the motherboard.
Here is an example of an IDE cable. If you can see there are tabs on the cable to make sure you line up the pins properly.
SATA = Serial Advanced Technology Attachment
This type is now the standard that most hard drives are. Also note that alot of your ROM drives are switching over to this format as well.
Here is an example of a SATA cable.
In regards to power connectors If you are using a PATA drive then you will use the Molex power connector. Note some of the early SATA drives use this power connector as well.
For the SATA drives you would use the SATA power connector. Note if your power supply does not have this connection you can get an adapter that goes from a Molex connection to the SATA connector.
Next you will need to find the connectors for the hard drive on your motherboard. Below if pictures of the 2 connection types.
IDE/PATA motherboard connectors
SATA motherboard connectors
on Sep 01, 2010 | Computers & Internet
Change my gx620 motherboard with ide connector for dvd rom to a 745 motherboard which has sata connection for dvd rom so i purchased a sata dvd rom and sata cable plugged everything in but the dvd rom wont...
With sata there are two cables, just like ide. One is the power and the other is for data. The data cable goes from the device to the motherboard. The power comes from the power supply. If your power supply does not have a sata connection you can purchase an adapter that will turn an available 4pin Molex into a sata connection.
http://www.ebay.com/sch/i.html?_nkw=ide+to+sata+adapter&_sacat=3667&_odkw=ide+to+sata+adapter&_osacat=42017&_trksid=p3286.c0.m270.l1313
Sep 11, 2011 | DELL 8X Serial ATA Slimline DVD-ROM Drive...
Recently changed the power supply. There is no video output. Where can I download the motherboard schematic?
Right here at HP Support,
1) Motherboard Specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00361570&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=459491
Scroll the page down to the top view illustration, and photo.
A) The motherboard uses a 24-pin ATX main power cable.
In the illustration the connector on the motherboard is on the right side.
It is an empty rectangular box with ATX Power Connector in it.
On the motherboard photo it is the rectangular white connector with two rows of 10 socket holes, and is to the bottom right of ram memory slot 2.
Another example of a 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Ensure that the 24-pin ATX main power cable's connector, is locked into place on the motherboard's connector. The lock tab on the main power cable must be hooked over the tab on the motherboard connector. This ensures that the main power cable is in all the way.
B) The motherboard uses a 4-pin ATX +12 Volt power cable.
The connector on the motherboard is a white square connector, with 4 socket holes.
In the illustration it is to the bottom left corner of the Processor socket (LGA 775), and has ATX12V underneath it. This power cable's connector also has a lock tab.
Another example of a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power TO the motherboard, that's it.
Power FROM the motherboard:
C) System Fan, and CPU (Processor) Fan.
Abbreviated as SYS_FAN, and CPU_FAN to the bottom left of the ATX12V connector.
(4-pin ATX +12 Volt connector on the motherboard)
The System Fan is the computer case fan.
CPU Fan is the Processor fan.
D) The four SATA headers on the bottom right in the photo, (Blue, Orange, Black, and White), are for the SATA data cables.
They connect to a SATA harddrive, or SATA optical drive. (CD/DVD drive)
(They are an L shaped connector inside, with 7 pins inside)
Power for these SATA devices comes from the Power Supply.
The Power Supply has SATA power cables.
Example of an average SATA power cable,
(L shaped connector with 15 pins inside. The longer connector between a SATA data cable, and a SATA power cable )
Did you forget which SATA data cable plugs into where, on the motherboard?
Don't sweat it.
The beauty of SATA is that you can plug the harddrive's SATA data cable into ANY of the SATA headers (Connectors) on the motherboard, and BIOS will find it.
Same with a SATA optical drive, or any SATA device, for that matter.
IF, your SATA harddrive has a place on the back for BOTH, a SATA power cable, and a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
Using both will eventually burn out the SATA harddrive!
Example of a 4-pin standard Peripheral power cable, (Misnomered as 'Molex'),
From there the main optical drive, (CD/DVD drive), has to have the audio cable plugged into the audio connector on the motherboard.
(Plus the power cable, and data cable, of course)
In the illustration this is the header down in the very far left corner, and located towards the bottom edge.
It has CD_IN marked underneath it.
In the photo it is the Black rectangular connector in the very far left corner.
If you didn't connect the 4-pin +12 Volt power cable, your Processor isn't getting any power.
No Processor operating, No computer.
No Signal on monitor.
(No video signal)
Regards,
joecoolvette
Jul 24, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Mar 30, 2009 | Intel Motherboard
HDD Connection
Hi, you'll need one of these: http://www.csncables.com/Cables-to-Go-1018X-GY1352.html (Data cable).
& one of these:
http://www.mwave.com/mwave/Skusearch_v2.asp?scriteria=BA00307 (Power cable IDE 4-pin to SATA drive). Unless your current power supply has a SATA power connector.
Open your manual to the top of page 1-24. SATA data cables connect one way only. It does not take much to break the ( L ) shape end of either the data cable or the SATA power cable.
(All SATA drives are seen a master drives). When in your bios choose the correct drive under Boot > Boot order.
Need more info, just ask.
Mike
Sep 09, 2008 | ASUS K8V-MX Motherboard
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
HOW TO CONNECT SAMSUNG DVD SH-203N TO A ASUS MOTHERBOARD
This is a SATA DVD Burner.
There should be a sata power and sata data cable
SATA POWER ADAPTER CABLE F is the power cable that attaches to the DVD the other end should be part of the power supply but if it isn't you would need this.
This is the SATA DATA cable would connect to the SATA point on the motherboard to the DVD burner, if the MOBO doesn't have this type connector on it you will need an ide to sata adapter
Apr 15, 2008 | Computers & Internet
Sata connection
u can connect through sata external casing
or if u have sata port on your motherboard then u can attach with sata cable and sata power cable
Mar 20, 2008 | ASUS P5RD1-VM Motherboard
Intel Motherboard Logo
270 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
