Question about Xerox Phaser 850DP Thermal Printer
Error code 09.037.45:35532
What is this error code? Can someone please tell me what this so that I can try to fix it. This is the first time we have ever seen this code and have no idea what it is.
Thanks.
Scott
  • ScottS829 Aug 04, 2008
    That was it. Got the stick out and replaced it. Now all is well.
    Thanks.
    President:
  • 2,072 Answers
That is a yellow ink stick count fault.
Most likely one of the yellow sticks has just gotten twisted in the loader and not advancing. May be cracked or damaged but for some reason not sliding down to the bottom and hitting the sensor.
Check the sticks and if you need to remove them just take a screw, like a drywall screw and twist it into the block to remove it.
If you managed somehow to get a stick in the machine from a different phaser product, it is shaped different and would not actuate the switch at the bottom of the ink loader.
Posted on Aug 04, 2008
  • Rick Kasper Aug 04, 2008
    Glad thats all it was. Your welcome.
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
How to remove error code on ford falcon radio
Read the operators manual and it will tell you what to do
Jul 14, 2014 | 1999 Ford Falcon
How do reset my canon mx370 printer error code 5b02
Have you tried disconnecting it from the mains supply for about 15 minuets ..? some times this clears the problem by wiping the memory,
but before you reconnect make sure you have ink and paper in the
machine.Otherwise contact Canon customer helpline they have someone there who can tell you what error 5B02 actually means ,T.C.
Mar 31, 2013 | Office Equipment & Supplies
I have Yahoo mail and Yahoo messenger on my phone. I can communicate by SMS to someone's phone or by IM to someone's messenger. When I try to sign in I get an error message. How can I fix it?
I've been having the exact same problem - which appears to have started at the same time as yours! I can't find how to fix it anywhere!
Dec 12, 2011 | Yahoo Messenger
Error on printer Connon ip 1000
Error code: 5600
Description: Cartridge displaced error
Symptom: blink in orange 9 times,beep 10 times
try removing and replacing the cartridge
please rate our help to keep the service online
Aug 24, 2009 | Epson Stylus Photo® R2400 InkJet Printer
I keep getting error code 800700F
1. Access: http://support.microsoft.com
and search for that error-code.
2. Microsoft offers _FREE_ telephone-support for all "security-update" problems. Call them.
Apr 03, 2009 | Microsoft Windows? Vista Home Premium...
Lens error code R740-033 on an HP R742 camera. Lenn will not close I have the same problem that my lens won't close and screen only shows Lens Error Code R740-033 It tells me to go to hp.com to get the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 12, 2008 | Cameras
Error code 7410: 0026060
7410 error
most likely you need to push the drum back till you hear click (drum at the left side at the prt)
Jul 10, 2008 | Kyocera FS-3900DN Laser Printer
Error message
Details please. Computer Type Operating System etc. Try booting from your OS CD, and see if you can get to a recovery console or DOS prompt and read the drive.
Jan 01, 2007 | Seagate Barracuda 7200.7 80 GB Hard Drive
Xerox Phaser 850DP Thermal Printer Logo
113 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
